Rear trailing arms collapsing in spring perch area
  • bimmer630
    • 1230
    I ran GC adjustable springs in the back of my car for a long time, and they started to bend the spring perch down and backwards slightly. I bent one trailing arm and replaced it, at the same time I swapped normal springs into the car with a stock set of struts up front too.
    Since the new trailing arm doesn't have a bent perch and the old one does, my ride height is uneven.
    Does anyone make a spring perch reinforcement or something like that? I was thinking someone must have some simple discs with holes in the center that you can weld in place to strengthen the perch area (?)
  • reelizmpro
    • 9558
    They have special perches or height jackers that flare out on the bottom to keep them from digging into the arm and disperse the forces over more area. What I did was buy two large 1/4" thick washers from Mc Master Carr.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • bimmer630
      • 1230
      My problem is, one side is already bent.. I wish I didnt run GC stuff on the street for so long
