Does rear toe-in mean new RTAB?
  • HerbE30
    • Nov 2015
    • 538
    Went for an alignment and learned that I have 0.98 toe... How? Why? Is the car ruined? RTAB and Subframe swap?
    Now inviting r3v members to the e30 bonfire. The one where the fire is composed of the e30s we've dumped thousands in for them to still be POS hoopties.
    20% Accurate
    Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
  • AndrewBird
    The Mad Scientist
    • 11896
    If it is equal on both sides, it is likely just worn out RTAB.
    Are you talking 0.98" or 0.98º? I'm assuming the former, which is a lot.
    • HerbE30
      • Nov 2015
      • 538
      It's not equal. They pulled me back in the shop because they say lots of mods and one of the guys had an 89.
      The rear subframe has been done - up with the condor special. But if you've seen the gauges on alignment machines the rear left was the only one with perfect toe. (I just installed new tie rods. That's why the front was off so bad. ) the rear right was buried to the left. So it's off... bad. I'm wondering if it's more likely in the rtab or subframe? Could a bend in the axle cause this?
      20% Accurate
      • HerbE30
        • Nov 2015
        • 538
        ° by the way
        20% Accurate
        • AndrewBird
          The Mad Scientist
          • 11896
          Bent trailing arm most likely if they aren't equal.
          • HerbE30
            • Nov 2015
            • 538
            Yeah, that was the plan as to where to start. I hope I can swap it without dropping the subframe again.. :(
            If that doesn't fix it. Classifieds will solve it.
            20% Accurate
            • HerbE30
              • Nov 2015
              • 538
              Still suffering..... Thanks to Ky poor support for anything noy Chevy, I can't find a rta.
              Does anyone think that the garagistic subframe correctors can adjust that out if its a uneven?
              20% Accurate
              • SkiFree
                • Jun 2011
                • 2766
                Weld-in camber and toe kits could take care of something like this. Will it be harder for you to drop the subframe and weld in the adjuster, or to locate a verified-unbent trailing arm?
                Bent trailing arms are not unheard of in an e9, 2002, e21, e30, z3, etc. You are coming off rather overly-dramatic. You will be fine, owning/maintaining/modifying an older car takes money.
                ADAMS Autosport
                • HerbE30
                  • Nov 2015
                  • 538
                  I've already had the subframe out to drop in codor 12mm riser and rtab. I may try to have those correctors installed and see. I agree with you though. Either way since it has been lowered the alignment will be toe in regardless. I worry because that would mean swapping trailing arms and bushings and just hoping for an alignment to be proper.
                  I realize it's a common issue, I've seen it over many threads. I just have a weird vibration at 80 ish now. Could this be related? Or may be the fault of tires?
                  I have spent lots of money already and plan to spend way more than I should. The plan is to have the chasis fully prepped and swap.
                  My e30 is also my daily. That's why I seem so rash about any imperfections. I commute about 40-50 miles daily, yes I do mourn those miles. But I wouldn't have them any other way.
                  Anyway, Ski, you have relieved me a little.
                  20% Accurate
