Grinding Noise when Turning (not a wheel bearing)
  • RichiesE30
    • Jul 2016
    • 37
    Hi guys, I'm a noob when it comes to e30s but I've enjoyed it since i've had mine.
    Now to the issue; I hear a grinding noise when making left turns only. I searched the forums and everyone with the same issue seemed to say that it was a wheel bearing/hub so I replaced it and no change. The noise is still there; the speed doesn't really matter, just gets louder as I go faster. Any help would be appreciated.
    Thanks!
  • Cayoncrusier93
    • Jan 2013
    • 204
    So it just happens when you turn?
    • RichiesE30
      • Jul 2016
      • 37
      Yeah and only when turning left. That's why I figured right front bearing
      • spike68
        • Apr 2009
        • 1185
        Take a look at the brake disks and check to see if there is any damage. Happened to me once. Also as a note, if you only replaced one wheel bearing there is a possibility it could be the other. The rule of thumb is that you should always replace front or back and not individually. I heard the good ole bearing whine and was convinced that it was the passenger side, but last minute figured it was the drivers side which ended up being the correct choice. Just a thought.
        I don't even own this car anymore, but I'm too lazy to change the picture.
        • RichiesE30
          • Jul 2016
          • 37
          Yeah I'm going to do the drivers side next paycheck, just didn't have the money at the time.. I'll get under it tomorrow and check things out
          • Das Delfin
            • Sep 2014
            • 2293
            I have a long and funny story that ends with you should just replace all four. The noise doesn't always come from the opposite side.. which was my case
            • TobyB
              • 5297
              I do 'em one at a time... and yeah, sometimes I get all the way to #4...
              But have you replaced your muffler bearings yet? Sometimes a broken hanger
              will let the exhaust system hit something only when you turn one way or another,
              and it can sound pretty gnarly...
              t
              • dsphil
                • 495
                Did you check your diff?
                327is
                325es
                325es
                318is
                Fiesta ST
                E46 M3
