What bushings would I need to replace to correct camber in the rear? One side is definitely visually lower and rubs my tire and nothing on other side. Rtab? I have fresh Billy sports and ie3 springs and the left definitely sits lower than the right.
Rear height issue
Originally posted by bblazen View PostWhat bushings would I need to replace to correct camber in the rear? One side is definitely visually lower and rubs my tire and nothing on other side. Rtab? I have fresh Billy sports and ie3 springs and the left definitely sits lower than the right.
Condor Speed Shop 12mm riser bushings are the only ones that I know of that have alignment correcting properties. Make sure your has the diff spacers and bolts included.
P.S. I use them in my car and it would have made my alignment almost perfect, aside from the Toe problem I have, which is unrelated to the bushings.20% Accurate
Morty: Well Summer maybe people that create things aren’t concerned with your delicate sensibilities you know? Maybe the species that communicate with each other through a filter of your comfort are less evolved that the ones that just communicate? Maybe your problems are your own to deal with and maybe the public giving a shit about your feelings is a one way ticket to extinction.
