steering rack crush washer
  • nlab
    • Apr 2017
    • 2
    So I converted to a Z3 rack, and the crush washer that goes in between the rack and the inner tie rods (the one that you hammer down onto the tie rod) will not work due to there being no slot on the rack for the tab on the washer to fit into.
    Has anyone else had this issue? Would using blue Loctite on the threads do the job instead? Thanks for any input.
  • Powling
    • Jan 2015
    • 1291
    I believe there are two types of washers that you can use. One washer for regular e36 racks with the notch, and the other is for hydro steering racks...not 100% sure if the z3 rack is hydro or not though.
    But I do know there are two types of washers. Might be worth looking into.
    Steve • Toronto
    1991 318is • Brillantrot
    Build Thread
    • Wolfman
      • 341
      34mm crows foot and tighten to 80 lb ft + loctite
      • nlab
        • Apr 2017
        • 2
        Right on! Thanks for the input / help - much appreciated!
        • jeffnhiscars
          • Jun 2011
          • 6011
          The reason rackdr ships his racks with inner tie rods pre installed is that there's a limit to how much torque you can apply without damaging the seals and/or bearings in the rack. He got tired of the resulting warranty claims
          Caution is the word
          Alice the Time Capsule
