Toe alignment specifications
  • mike87
    • 300
    Hello r3v, I need some help figuring out what toe spec I should run on my E30. It's lowered on H&R race with bilstein sport shocks/struts. OEM mounts all around, no camber plates, no eccentic bolts for the rear subframe.
    Tires are Federal 595 RS-RR 205/50/15, car is for mainly for the street, autoX sometimes
    I know a bone stock E30 should be at 0.08 inch total toe per the bentley manual Section 14, 4.3 Alignment Specifications, which is "toe-in" I believe.
    Does anyone have any recommendations as to what I should have the shop set my toe at?
    Bentley front E30 alignment specifications:
    Bentley rear E30 alignment specifications:
  • redlightpete
    • Mar 2012
    • 263
    I just run mine with zero toe. It is plenty stable with no toe-in and it should minimize tire wear.
    • redlightpete
      • Mar 2012
      • 263
      Also, unless you know your car is tweaked, I wouldn't bother getting a shop alignment. The only thing that is adjustable is front toe, and you can do that yourself. Just line up the front wheels with the rears using a string or tape measure.
      • mike87
        • 300
        Thanks for the advice! I would love to do it myself, except I have a feeling my rears are toe-in and won't be able to give me a reliable baseline for the fronts.
        I've seen the longacre toe plates too, and while they work for correcting toe, they can't determine the overall direction both wheels are pointing
        • Jb325is
          • 2137
          Just get toe plates. Run zero toe for the street, and bump it up to ~1/8" toe out for autocross. Set toe, drive car. If it pulls, do even adjustments (out on left, in on right) as needed, make sure toe is still good.
          - '88 m54 coupe
          <3
          • mike87
            • 300
            this is exactly what I did! longacre toe plates did the trick, running total of 1/8" toe out
