Ground Control Kit on M3 advice needed
  • djafactor
    • Jan 2009
    • 60
    Hi guys
    Just installed my GC conversion kit and wanted to get some advice on how my car is sitting.
    Car is an 89 M3 with the GC kit with GC koni struts in the stock full length housings on stock tower mounts. Wheels are 16x8 on 225/45/16
    Below is a pic of how the car currently sits. I find the front sitting higher than I thought it would. If I adjust the sleeve ring any lower the bump stops sit on the GC sleeves.
    The car had h&r sports previously and it sat a bit lower so I'm not sure if this GC kit should sit the same or lower.
    I'm going to order the GC hybrid camber plates tomorrow which are shorter heights than the stock tower mounts so should make the car sit better. Just wanted to have any thoughts of how it sits for those that have a similar setup
    Also included some pics of the front installed kit (note this this is with the car on jack stands). Apologize for the dirt it hasn't stopped raining the last few days.
    Cheers
    '89 BMW M3
    '94 BMW 318i Touring
    '11 BMW 1M
    '97 BMW 328i
    '89 BMW 325i w/M52 (Race Car)
    pixsoul.ca | electricpixel.ca
  • reelizmpro
    • 9534
    Since you are still running full length housings with perches you need lower stack height mounts/camber plates and/or shorter stiffer springs.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • earthwormjim
      • Jul 2014
      • 434
      You didn't trim your bump stops, the "directions" GC supplies says to cut them basically in half.
      You really should cut off the spring perch too, that's propping your sleeve ring up quite a bit.
      • djafactor
        • Jan 2009
        • 60
        Thanks. Have since done so. Also added the GC camber plates which helped and now just received 5" springs from GC to try
        '89 BMW M3
        '11 BMW 1M
        '97 BMW 328i
        • M-technik-3
          • 18946
          Having sourced 5" springs will allow you to get lower but be aware you might bottom out your koni's which will damage them internally and that is not covered with altered bump stops.
          The alternative is to find a set of E30 M3 struts that have had the perches modified already and weld on ring to hold the adjusters so you can use a 6" spring allowing full travel.
          J-stock
          • djafactor
            • Jan 2009
            • 60
            Cheers. I installed the 5" springs and trimmed the top of the GC sleeve so it's more flush with the top of the strut. This gave me a half inch more strut travel before bottoming out. Been driving around our horrendous Montreal roads the last couple of days trying to test the limits of travel and all seems good with no bottoming out. I just adjusted it up another 1/4" from the following pic so should be good to go for my Monday alignment appointment.
            Thanks
            '89 BMW M3
            '11 BMW 1M
            '97 BMW 328i
            • DRTSRFR
              • May 2008
              • 1836
              The GC sleeve is not seated correctly. There should be no stock hardware underneath it. I believe I see the nylon ring in there.
              Also, you lose some drop due to the factory perch being retained which limits the downward adjustment of the gold nut.
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • M-technik-3
                • 18946
                You don't want to know the price of an e30 M3 strut tube this is why he did not cut the perch off to go lower.
                • djafactor
                  • Jan 2009
                  • 60
                  Yeah at $1200 per housing I definitely was not going to cut anything. The 5” springs have worked out great. No bottoming out and the fit and ride is excellent. Super happy with the results.
                  '89 BMW M3
                  '11 BMW 1M
                  '97 BMW 328i
                  • CMG
                    • Apr 2008
                    • 736
                    By chance would you be able to snap a couple of pics of the top and bottom of your GC camber plates? My GC plates don't have any markings for side or orientation, and I'm trying to confirm correct set up. Thanks.
