Bad Tire Rub
  • redsubdivisions
    • Feb 2011
    • 1762
    I have the same problem with mine. I have rubbed my rears down pretty good as well with Style 5's from an E38. I'm in the process of trying to eliminate that by either getting a proper 5-lug setup (M3's in front, Z3M for the rear and snagging some E46/E36 wheels) or just ditching the adapters and going back to lightweight 14's or 15's in a 4x100 pattern with some solid brakes.
    1989 325i - 2.7i, Holset H1C, 60lb injectors, whodwho MS-PNP.
    2012 Passat TDI - DD Duty
    2008 GMC Yukon XL Denali - Kiddie hauler/grocery getter
    • Junk_30
      • Sep 2017
      • 13
      Obviously if I had the money id be looking into a 5 lug setup but obviously I dont, Ive been looking into getting my wheels re-drilled but it seems expensive
      • e30davie
        • Apr 2016
        • 1788
        Have you actually rang anybody for a quotation?
        For the price of a 5 studd conversion you can buy whatever 4 stud wheels you like. brand new ronal LS or even some flash BBS in the correct size.
        If i were you id sell the wheels and spacers as a kit to someone else to try and make them fit, and use that money to buy wheels that fit properly:)
        • IRON-E
          • 16548
          Originally posted by Junk_30
          Would anyone know how to get these redrilled
          I usually do it for $240 all 4 wheels, filled then drilled.
          Your set up needs to be at a 205/40/16 or 205/45/16 also, the brand of tire matters as some higher end brands run wider than the cheaper brands. For example federals 205s fit like a 215 tire, hence the nickname FATERALS.
          @IRON-E30 aka Edwin:D
          • LateFan
            • May 2013
            • 4432
            Ideas:
            949 Racing SpecE30 wheels
            http://949racing.com/15x7-6UL-SE30.aspx
            Or TR Motorsports at Tire Rack
            • Junk_30
              • Sep 2017
              • 13
              Thanks for the help ill call around in my area, just curious, how does the process of refilling work, i.e. what do you fill it with
