Drivers Front Caster Issue
  • 86bmw325e
    • Oct 2014
    • 89
    So I had my car aligned after replacing the inner and out tie rods today, and it looks pretty good for he most part. The one thing that really stuck out was the left front caster is a whole degree more negative than the right front. What am I miss that could cause this? Car is mostly stock, but has stock offset Condor CAB’s with lollipops they supplied. Left front control arm looks never than the right front but not sure. What should I look for?
    1990 BMW 325i Sedan
    Mods:
    -Condor Poly CABs
  • earthwormjim
    • Jul 2014
    • 434
    Are the offset bushings both aligned the same way? The hole in the lolipop bushing should be closer to the mounting tab.
    • 86bmw325e
      • Oct 2014
      • 89
      Took some measurements today while the car was on stands. Bushings are oriented correctly, drivers wheel is about 1/4” further back than passenger. Measured subframe and found the drivers side about a 1/4” back when measured from radiator support.
      Can the subframe be loosened and moved like in Audi’s? Or is it fixed by dowels?
      1990 BMW 325i Sedan
      Mods:
      -Condor Poly CABs
      • iPee
        • Nov 2013
        • 190
        The subframe is fixed and should not move.
        • jeffnhiscars
          • Jun 2011
          • 6011
          But I'd bet there is enough play in the bolt holes that you might be able to even this out....assuming nothing is bent
          Alice the Time Capsule
