Front suspension lift
  • benjamin
    • 174
    I am looking to lift my front suspension a little bit. Does anyone know where I can get some spacers like these?
    Thanks!
  • ak-
    • 12422
    Add spring pads and get a new pair of top hats - old ones/originals collapse over time.
    1991 325iS turbo
    • benjamin
      • 174
      My top hats have less then 2,000 miles on them. Maybe I can add a spring pad though?
      I’ve got vogtland springs and KYB’s. Love the comfortable ride, but I want to bring the front up to match the back.
      • Chrisbike
        • Mar 2015
        • 688
        How tall are stock e30 Springs? I think the IX springs will give a inch or so (I have a refinished set I’m not using since I went to coilovers)...
        Build Thread
        https://www.r3vlimited.com/board/sho...d.php?t=419655
        Parts Thread
        https://www.r3vlimited.com/board/sho...d.php?t=408302
        • jeffnhiscars
          • Jun 2011
          • 6011
          Ak is showing a strut mount which could be at fault. Top hats are metal and if someone put in an e90 version you can go back to stock to gain a bit of height. You can also get thicker spring pads
          Alice the Time Capsule
          • benjamin
            • 174
            Hey guys really appericate all the replies.
            My suspension is all in proper working order. I replaced the stock setup with Vogtland springs and KYBÂ’s about 2,000 miles ago. At that time, I replaced the top hats with good quality German made e30 units, but reused the original spring pads. Suspension works great, just looking to lift the front up without replacing the springs.
            • benjamin
              • 174
              Thicker spring pads may be a good place to start. What’s the thickest option?
              • jeffnhiscars
                • Jun 2011
                • 6011
                I believe they go 3 (stock), 5 & 10mm and that you also stack them for fine tuning.
                • benjamin
                  • 174
                  Excellent, thank you. Do you think stacking 3 of the 10mm will be too much? Also, just want to clarify before I place my order, I just want to stack the top pads, and keep one bottom pad?
