i put an e46 steering rack in my e30 and the e46 rack came with what looks to be a check valve built into the pressure line bolt on the rack itself. now the e30 had no check valve in the pressure line bolt. should i run the check valve or no check valve? thanks.
e46 rack swap check valve
Originally posted by bluedxj View Posti put an e46 steering rack in my e30 and the e46 rack came with what looks to be a check valve built into the pressure line bolt on the rack itself. now the e30 had no check valve in the pressure line bolt. should i run the check valve or no check valve? thanks.
