do u need the tie rods too, or just the rack?? any issues with the power steering when this mod is done?
Zionsville quick ratio kit impressions....
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image. -
you can use E30 tie rods, but if it comes with E36 rods, use em.Recent Rebranding!!
E30 SM62/S62
E30 M60 V8
E30 M30 Big 6!
Instagram.com/garageaholic
Youtube.com/garageaholicComment
thanksCheck out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I have the Z3 rack in my race car and it was a night and day difference, I now have awesome control and correction response time. Definitely knocked time off my runs. Also didn't have to use the E36 hose just creatively adjusted the stock hose.
Now my 325es has the 95 M3 rack and that is perfect since the Z3 rack can get twitchy at high speeds. So the 95 M3 rack in my opinion is perfect for a daily driver upgrade.
My .02,
RODDComment
The 95 M3 rack and Z3 rack have identical steering ratio's, so one cannot be "twitchier" then another. They cannot be variable ratio as it is a straight rack and pinion.I have the Z3 rack in my race car and it was a night and day difference, I now have awesome control and correction response time. Definitely knocked time off my runs. Also didn't have to use the E36 hose just creatively adjusted the stock hose.
My .02,
RODD
The only difference is the lock-to-lock distance, 2.7 for the Z3 vs. 3.0 for the 95 M3.
It's probably CAB's, alignment, tires, or something of that sort creating the "twitchy" feeling.Comment
There are steering stops, usually where the knuckle hits the control arm. Rack and pinions have a ratio the same as ring and pinions. The ring gear is just flat. Are the lower number of turns peculiar to the Z3's steering stops or to the rack travel? Common sense would tend to think you could use the same racks as other body styles and just limit travel at the control arm steering knuckle.It may be just less room in the roadster body's wheel wells for wider tires and wheels. The actual spec for racks is in terms of rack travel for pinion rotation.
Yes, so stfu. Remove the plastic steering stops from the 2.7 rack and it becomes a 3.0 rack with identical ratio to the m3 rack, ie the same thing. There is zero benefit to the z3 rack.
SamComment
I have a Z3 rack (pretty sure anyway) and it turns just as far as my original rack. If it went any further, it would just be up against my fender walls. So, I'm not sure what everyone's talking about with the Z3 rack causing less travel overall - because it's identical for me.
It's insanely short. When I first jumped in the car, it was night and day, and even took some getting used to. My friend had to get used to it too when he drove, and even my dad (who has a 95 M3...btw). I'm used to it now though, I can just turn insanely fast when stopped. ;)
I love this rack, and it's seriously, along with my suspension and motor, one of the best mods I've done to date. It makes autocrossing much smoother, and when driving on the track, I don't recall my hands ever having to leave 9 and 3!
Z3 rack FTMFW!!! :D- Sean HayesComment
eh, i have a z3 rack sitting in a pile with the rest of my parts whoreing. i tested it by hand, 2.7 LTL, although, if the above is true about removing some plastic steering stops and having the same specs as a 95 M3 rack, then i would rather just go that route, as i wanted the 3.0LTL rack anywayz.IG: @Baye30
FRONT VALENCE IS ZENDER!!! STOP FILLING MY PM BOX PPL!!!Comment
I never saw any plastic stops? Where are they?eh, i have a z3 rack sitting in a pile with the rest of my parts whoreing. i tested it by hand, 2.7 LTL, although, if the above is true about removing some plastic steering stops and having the same specs as a 95 M3 rack, then i would rather just go that route, as i wanted the 3.0LTL rack anywayz.- Sean HayesComment
