Small project - E30 M3 springs refurbished
  • finnmole
    • Sep 2018
    • 76
    My stock height on the 325 iS is the same as your 318 iS
    I think even the small drop makes a difference though...looks good.
    • majdomo
      • Jun 2018
      • 449
      Pic from tonight, installed the rear H&R OE Sports. Comparing E30 M3 to OE Sport to 318is stock:
      Ezekiel 25:17
      Current flame: E30 318iS Alpinweiss II slicktop / LSD - Joanne
      The old man: 1970 2002 Polaris(ish) slicktop / rat rod - Wallace
      The ex: E92 335i 6MT M-Sport - Betty
      The heavy: 2001 4Runner SR5 Sport (3rd Gen) - Fred
      • majdomo
        • Jun 2018
        • 449
        With OE Sports installed, front:
        Rear:
        Rides just awesome on these now, body roll is noticeably reduced as are road imperfections. The car feels way smoother than it did before.
        Ezekiel 25:17
        • majdomo
          • Jun 2018
          • 449
          All done, now on Euroweaves and Direzzas:
          Ezekiel 25:17
          • mike.bmw
            • Dec 2015
            • 1777
            Looks great! That ride height looks perfect. Sorry I didn't see this thread earlier or I would've chimed in with some info/measurements.
            Did you see my post with measurements for H&R OE sports on my 318is?
            Did you end up using the 14.5mm E46 rear spring pads? That'll give you another half inch of ride height in the rear.
            • majdomo
              • Jun 2018
              • 449
              Thanks Mike! I did see that thread, stayed with the stock rear spring pads for now as I wanted to see how it looked first. Seems fine for now but may change my mind later, it looks a little bit droopy drawers in the back.
              I also ended up going with 50s instead of 55s. The look is a little bit odd...but I really wanted to kill as much roll as possible. I may swap them out, but I just drove my local twisty backroad and the handling is awesome, way more confidence inspiring than before!
              Ezekiel 25:17
              • majdomo
                • Jun 2018
                • 449
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  With the Allen hole stripped I've still been able to torque the damper nut by locking a vice grip over a rag at the very top of the rod....high enough so if it does get chewed it won't reach the seal. You only need 17lbs
                  Alice the Time Capsule
