Re-use CAB's?
  • Jbpka06
    • Feb 2006
    • 551
    Re-use CAB's?
    My ball joints are worn out and need replacing. I replaced the control arm bushings about 5000 miles ago with M3 CABs. They have no wear. Is it possible to reuse them by putting them on my new control arms?
    • 34839
    unfortunately, no.
    • erik325i
      • Jan 2005
      • 3567
      Originally posted by nando
      unfortunately, no.
      Why not? I've successfully removed CABs from the control arm before without damaging the bushing. I don't see why you wouldn't be able to reuse the bushing after that.
      -Erik
      • Simon S
        • Oct 2004
        • 3758
        that would be the trick.
        you just pull it off w/ a 3-jaw puller?
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • Mike325
          • Mar 2006
          • 3685
          You can reuse them no prob.
          Originally posted by Kershaw
          • Jbpka06
            • Feb 2006
            • 551
            What is the best way to get them off?
            • Mike325
              • Mar 2006
              • 3685
              Take some silicone spray and spray around where the cab is on the control arm. You may need a puller. I got mine off by hand, but they only has 200 miles on them.
              • Brew
                • 3060
                If they are fairly new you should be able to pull them off of the control arms with your bare hands. A little bit of penetrating oil work wonders.
                '91 318is
                • Jbpka06
                  • Feb 2006
                  • 551
                  Well they have about 5k on them.
                  • erik325i
                    • Jan 2005
                    • 3567
                    I just used a ball joint press tool. Came off no problem.
                    -Erik
                    • kishg
                      • Sep 2006
                      • 2624
                      does re-using a CAB have any adverse effects on how well the arm is held in the CAB? doesnt the arm set in the CAB when you first install it? im replacing my control arms and i know the PO installed M3 CABs less than 5k miles ago. should i reuse them?
                      '12 F30 328i Sport Line
                      '91 SpecE30 #523
                      '00 Ford F-350 Dually Tow Vehicle
                      BMWCCA #360858 NASA #
                      128290
                      • 2002maniac
                        • 4260
                        I have found that simple green is the best lubricant for rubber bushings. It makes them totally slimy.
                        • StereoInstaller1
                          GAS
                          • 22679
                          May I suggest just buying ball joints instead of replacing the entire arm? You can usually find them for about $20 each. If you take them to a local machine shop, you should be able to get all 4 pressed in and out for about $20.
                          At least that has been my experience.
                          Luke
                          Closing SOON!
                          Thanks for 10 years of fun!
                          • Jbpka06
                            • Feb 2006
                            • 551
                            sometimes old control arms are bent depending on how many potholes you hit
                            I re-used my CABs with about 5000 on them and it was fine.
                            • kishg
                              • Sep 2006
                              • 2624
                              any tips on how you got them off the control arm?
                              '91 SpecE30 #523
                              128290
