Difference between Bilstein, Bilstein HD, Bilstein Sports?
  • ptownTSI
    • Jun 2005
    • 1265
    now i'm a bit confused. can someone explain the differences?
  • backtrail69
    • Jul 2005
    • 4471
    Bilstein is just a brand name Bilstein sports and HDs have the same valving, but the HD is designed for stockish ride height and the sports are designed for lowering springs.
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • Mike325
      • Mar 2006
      • 3685
      I have the bilstein tourings on my car and they are the tits.
      Originally posted by Kershaw
      • ptownTSI
        • Jun 2005
        • 1265
        yes bilstein is the brand but some are just labeled "Bilstein for e30" whereas others are "sport" or "HD", are the non labeled ones the "touring" are they softer than the others?
        • smonkbmw
          Professor
          • Jun 2006
          • 4549
          yes they are softer. hds are a bit stiffer, the sports are revalved, have a huge piston, and the piston is shorter for using lowering springs with.
          • Mike325
            • Mar 2006
            • 3685
            Yes, the tourings are for a softer ride. I have them in the front right now and they feel great. You still get the lovering, but the ride feels very responsive, yet won't kick your ass over the bumps. I have eibach springs.
            • Rocla
              • 922
              In fact the piston on Bilstein sports is thinner than most of any e30 front shocks. The thick metal tha comes out from shock is in fact the "pump", bilstein shocks are constructed "upsidedown", so the real piston mounts to the bottom of the insert housing and upper mount is on "bottom" and of the pump.
              Current:
              BMW 320i 2d 2.0 m20 -88
              BMW 325i Cabriolet 2.5 m50 -88
              BMW 316i touring 1.6 m40 -90
              BMW 320i 4d 2,2 m54 -01
              • smonkbmw
                Professor
                • Jun 2006
                • 4549
                my mistake, i forgot on e30s the shocks in front are inserts. i was referring to the ones i had on my e36 without realizing, my mistake.
                • matt
                  • 3732
                  They're probably the same way too.
                  All Bilstein shocks are gas charged. Not that that's all that important to you guys, but I'll throw it out there.
