hey guys, i was wondering if any1 knew the position for the m3 endlink tabs when welding them onto a non-m e30? maybe if some has a good pic of the m3 strut out of the car? thanks for any help.
mounting location for m3 endlink tabs
Positioning doesn't have to be perfect, especially if you use adjustable end-links (i.e. IE, or GC), however I prefer to have them about 0.75" to 1.0" below the perch. You do want to make the measurement the same on each side though to eliminate any unwanted preload.- Jason
My factory strut housings measure 12 5/8" from the end where the bolts hold the endplate on to the center of the hole. I just went and double checked. If you need any pics LMK, mine won't be back on the car for a couple days. Also, factory is a wimpy 1/8" piece, mine are now 1/4" thick and the factory welds are all backwelded in addition to new metal laid down.
-B
It's not how you handle the good times, but the faith you keep in the bad that defines you.Comment
