3 holes on Eibach Sway Bar? What's the diff?
  • Maluco
    • Oct 2005
    • 6572
    What's the difference in connecting the sway bar link to each of these 3 different holes/settings? Which one should I connect it too? (I'm removing it from one E30 and putting it on mine) Thanks
  • browntown
    • Jun 2004
    • 3524
    It *may* have something to do with the leverage point and change it's effectiveness, but I'm not sure. Personally I'd mount in the hole that gives you a perpindicular sway link under load.
    • matt
      • 3732
      First part is right, second part notsomuch.
      The farther the link connects, the softer the sway bar will be.
      • Maluco
        • Oct 2005
        • 6572
        so in the picture, which one should I set it too? It's currently in the middle one. I'll eventually be lowering my car and it's a DD.
        • matt
          • 3732
          Front sway bar set all the way stiff, rear set all the way loose.
          • Fidhle007
            I can fly, motherfucker
            • Oct 2005
            • 7209
            It's more fun the other way around though... ;)
            '89 325is S50 Track Montser
            '04 X5 Daily/Tow Vehicle
            http://www.avarestoration.com
            http://www.myspace.com/brendanfiddle
            Click here if you want to be my zombie slave...
            http://www.youtube.com/user/Fidhle007
            • Maluco
              • Oct 2005
              • 6572
              Please explain...
              • trent
                Originally posted by Maluco
                Please explain...
                A tighter rear sway bar means more oversteer, so these idiot kids can "dorifto"
                • Fidhle007
                  • Oct 2005
                  • 7209
                  You realize I was kidding, right?
                  • Maluco
                    • Oct 2005
                    • 6572
                    That's not the rear sway bar in the picture....
                    • 1991 318is
                      • Dec 2005
                      • 786
                      Sway bars increase the spring rate during cornering. The problem is that the makers don't tell us, or more likely, don't even know how much. Rousch Racing's cars have had some really good designs and made them in house using tube. Diameter stays the same but the wall thickness is different. They all use the same mounts, arms, etc.
                      On your bar, the hole closest to the bar is the stiffest setting and the one all the way out to the end of the arm is the softest. You should put it in the one that you think makes the car work the best on the track or the way you like it best if it's a daily driver. Personally, I like stiff sway bars.
                      • Maluco
                        • Oct 2005
                        • 6572
                        Ok, so the hole furthest towards the front bumper is the stiffest? It seemed it was previously stated that the hole furthest from the front bumper was the stiffest... although the way it was written/stated was a little confusing. I also don't mind stiffness....
                        • Rocla
                          • 922
                          The hole that gives the shorters measure for the bar is the stiffest setting. In front bar the on that is closest to rear bumper :)
                          More leverage=looser, less leverage stiffer.
                          Current:
                          BMW 320i 2d 2.0 m20 -88
                          BMW 325i Cabriolet 2.5 m50 -88
                          BMW 316i touring 1.6 m40 -90
                          BMW 320i 4d 2,2 m54 -01
                          • matt
                            • 3732
                            I didn't say anything about any bumpers.
                            I swear we should have a requirement that you got a B or better in highschool physics before you should be allowed to post here. Leverage is such a simple concept.
                            • Fidhle007
                              • Oct 2005
                              • 7209
                              ;) I concur.
