The holes at the end of the bar are softer. As you move away from the end it'll get stiffer.
If your endlinks are fixed liked OE links, then make sure the hole on the left is the same as the hole on the right.
If you have adjustable endlinks, then you can mix and match the left/right side to come up with 6 settings instead of just 3. Just make sure you adjust those endlinks with the car on the ground so you introduce as little preload as possible.
