318ic convertible suspension upgrade?
  • bmwpower
    • 1556
    Who makes struts/shocks and springs that will work on this car (It's a 91)? I've looked at a lot of places and they all do not make parts specific for this car.
    Realoem says:
    The FRONT springs are different than a late 325ic
    The REAR springs are the same
    The FRONT struts are the same
    The REAR shocks are the same
    So is it safe to assume I can use struts/shocks from a 325is, but not the springs?
    So which springs will work?
    I'm not looking for something that's slammed, just something will a little drop like my Eibach Prokit on my 87 325ic.
    89 325is track project / 05 x5 / 99 M3
    E30 stuff for sale | Parts I'm looking for
  • jtb_29
    • Oct 2006
    • 273
    I don't have any first hand experience with convertible suspensions but if the front struts are the same I don't see why the springs wouldn't fit unless they just have a different part number on realoem.com because they have a different spring rate because of different vehicle weights. Just a guess but I don't see why it wouldn't work. Try searching a little.
    edit: Did it for you..
    The grilles really distract you from the fact that someone took a sledgehammer to the front end.
    • parkerbink
      • Jun 2004
      • 10138
      The suspensions are very similar if not the same. I had Bilstein Touring shocks & M3 springs that worked very well together on my 325ic.
      • bmwpower
        • 1556
        I can only assume the FACTORY front springs are different since the vehicle weights are different in the front due to the engine.
        I should probably just go with what I have on my 325ic since I like the combo.
        I've got the Bilstein Sports and Eibach Prokit on the 325ic.
