rear shock mounts
  • viali8
    • Nov 2005
    • 673
    rear shock mounts
    Just recently i noticed a noise in the rear of my car and checked my rear shock mounts. The rubber on one of them is starting to rip. I have Bilstein HD shocks with relatively new OEM shock mounts that are less then 4 yrs old. I think the shocks are too stiff for the mounts. Can anyone recommend something stronger so the mounts will not fail. Keep in mind that this is a daily driver and i do not track or anything like that. Just some spirited driving every now and then:) thanks Matt
  • golde30
    • 11464
    4yrs is a long life span for OE shock mounts... why dont u try some e46 m3 cabby RSM.
    IG: @Baye30
    • Jand3rson
      • 37587
      Go with the Bimmerworld Lifetime RSM's. Built to the same specs as E46 M3, better materials, and lifetime warranty on them.
      • viali8
        • Nov 2005
        • 673
        ok i will check them out. thanks
        • viali8
          • Nov 2005
          • 673
          Which one should i buy?
          The 3 series lifetime warranty RSM or
          The 3 series RSM stock Heavy duty
          • viali8
            • Nov 2005
            • 673
            which ones?
            Anyone?
            • PiercedE30
              • Apr 2005
              • 4220
              My 2.9L Build!
              • viali8
                • Nov 2005
                • 673
                cool thanks
                • viali8
                  • Nov 2005
                  • 673
                  i just received my RSM from bimmerworld. They are the mounts with the lifetime warranty. I have not installed them yet and i have a question. If i remember correctly there is a cup shaped washer. What is the correct way to install this washer? cup up or cup down? thanks matt
                  • e30lyf
                    • May 2007
                    • 4552
                    as far i know is cup up.
                    - Fercy -
                    Classic BMW Specialists
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • viali8
                      • Nov 2005
                      • 673
                      Can i use the existing hardware to install the new RSM. When i spoke with guy from bimmerworld he told me that i needed two 10mm washers for each strut. Therefore do i need to purchase the 10mm washers or can i use the existing hardware which is the OEM hardware. thanks
                      • Schneider325
                        • May 2004
                        • 3818
                        ^ Technically you would want to replace all three nuts on both sides, since they are self locking. You can reuse the washers. Make sure the on top is cupped up and the one below the mount is cupped down
                        • viali8
                          • Nov 2005
                          • 673
                          great thats exactly what i needed. i was not sure which way the cupped washers were to be installed. thanks matt
