Tie rod scraping wheel
  • E-Thirty
    • 1331
    I just installed H&R springs, KYB shock, control arms, control arm bushings, and tie rod ends. When I took the car out, the bottom of the tie rod end on the driver side front was scraping against the wheel...Where did I fuck up?
    Do you feel like something is trying to penetrate your butthole?
  • twothrees
    • 252
    When I installed my new tie rod ends(KO Performance, I got the cheaper brand) I encountered the same problem. I found out that the head was larger than the one I took off, which is why it was scraping. Luckily, I was switching out my bottlecaps to
    16" slipstreams. This obviously solved the problem.
    • E-Thirty
      • 1331
      I just checked and they are pretty much the same size as the stock... how close do they normally ride on stock suspension with bottle caps?
        I've seen this before with non-OE tie rod ends. There's very little clearance between the tie rod end and an OE wheel. So even a bit of dimensional difference causes a problem. Ditch the aftermarket parts and use the OE parts and you should be fine.
        • E-Thirty
          • 1331
          You guys were absolutely right. Upon inspection in the day time and no alcohol, I can actually see quite a bit of difference in the sizes, not to mention the oem ones thread in even deeper. The tie rod was literally shaving the inside of my wheel like a potato peeler.
            That's why I'm very cautious about using non-OE parts.
            • Flash
              • 687
              I had this same problem on the super eta when i rebuilt the front suspension, i didnt have the tools so i had to pay a shop to do it AGAIN which cost 90 plus parts and alignment finally...
              • E-Thirty
                • 1331
                I just can't believe how close the tie rod is to the wheel by oem spec.
                • xLibelle
                  • Aug 2004
                  • 2673
                  file down the side to make for clearance.
