THR CAB's
  • DoriftuEvo
    • 236
    Yes, bearings are METAL balls. So why would you think hard plastic would stiffer?
    Regardless of the material being used, it appears to me that the AKG bearings are spherical type bearings and would allow rotational movement around the Z and X axes as shown in the above image. That's why I think the "feel" would be stiffer with the THR units. Linear axial movement might be stiffer in the AKG units due to the use of harder materials. This is speculation. I don't claim to have done any analysis deeper than that.
    Maybe the bearing is simply for ease of installation and the suspension doesn't realistically flex in that way. Maybe the bearings aren't even spherical and I need glasses or a bigger picture to look at.
    • CorvallisBMW
      Long Schlong Longhammer
      • 13039
      ^ spoken like a true engineer! awesome.
      • scabzzzz
        Estado de mierda de encargo
        • 6871
        Search this up. Theres been numerous threads about the THR Eyeball arms with a lot of debate. They are superior to most everything else.
        • iwantone
          • Dec 2006
          • 57
          you do not NEED them for a swaped car, i use regular m3 bushings for my m50 swap and works fine. but with that said, i do plan on purchasing these down the line because i think they will help the little shimmy my car has at high speeds and should make the front end feel more solid.
          • fretburnr
            • Jan 2005
            • 1496
            Another benefit to the treehouse units is ease of installation. Unlike any bushing that uses the stock lollipops, these don't require a press to install. Road feel is superb, and the benefits of m3 geometry are well documented. Due to the minimal flex, turn in is excellent.
            Also, those spherical bearings would require periodic lubrication or inspection, and would be susceptible to damage from dirt and debris on a street car.
            Pardon my lack of spacing... i'm typing this on a phone.
            Jay
            • e30 gangsta
              • 3877
              So i have normal poly bushings non offset. And im running a s52 header. Will it clear?
              • CorvallisBMW
                • 13039
                huh, so it looks like I have a decision to make. I don't want to 'vert to be too stiff since it will be a dd (which is why I was planning on doing M3 offsets), but if the THRs are that much better as far as feel/control, and there is little, if any, loss of comfort, I may have to go with them.
                • Sean
                  • 5793
                  I honstly didn't notice any loss in comfort. The loss of my comfort is felt by my Konis and IE Stg 3s. All the THR bushings do is let you feel more road irregularities with your wheel - which honestly isn't that bad. But, with soft suspension, I don't think I'd even notice a change.
                  I love being able to feel everything. Granted, it sucks going fast thru a really bumper turn...actually, it's impossible. But smooth roads are heavan! :D
                  - Sean Hayes
                  • z31maniac
                    • 17566
                    Good explanation.
                    Ahhh yes, the I don't have anything to offer in this thread response.
                    But way to suggest a search when the thread is on its second page.
                    www.gutenparts.com
                    • Wishno87
                      • 6025
                      Yes guys I'm bumping a fossilized thread but I was wondering if anyone could tell me what sort of grease if any I should apply when installing the CABs. I heard that squeaking was an issue with these if they are not properly lubricated.
                      • Sean
                        • 5793
                        He used different bushing material - never a squeak. Since I put the new bushing in, they are silent. However - the arms themselves have NO powdercoat left - I need to recoat them.
                        - Sean Hayes
                        • Wishno87
                          • 6025
                          So no lubrication then?
                          • Gooch
                            • Dec 2006
                            • 1674
                            Nope. No squeaks or other noises here either.
                            '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                            '87 535i - Vacuum brake conversion [SOLD]
                            '93 525iT - 5-speed swap - 320k and counting
                            '09 328xi - 6-speed
                            • Wishno87
                              • 6025
                              Good to know, thanks guys!
                              • Sean
                                • 5793
                                Depends on the condition of the control arm rod.....
                                - Sean Hayes
