zionsville steering rack conversion?
  • Brian 89 325i
    • 1450
    I was just checking that out and the have a 2.70 rack now. What car is that from?
    Brian
  • MattM20
    • 641
    a Z3. ive been calling them for 4 months now, and they never have any in stock. they wont even sell the modified coupler without one of their used racks.
    • Rob
      • 8166
      that would almost be too quick for a street car....I absolutely love the rack in an 95 m3 however, whats that? 3.2?
      I know I've asked this before, but I wonder if you can do this with a 90-91 since is says "Non-Airbag cars only". I guess that means cars with existing airbags, unlike mine haha
      BEERTECH
      • MattM20
        • 641
        3.0 according to zionsville
        i think current non-M e46's use 3.0 aswell
        • Addissimo
          • Mar 2004
          • 1820
          just any old z3? Doesnt have to be powered by M otorsport?
          Doing something M50 related? -> http://www.addissimo.com
          On Myspace? ->http://groups.myspace.com/r3vlimited
          BF2142 SN = BillyGoose
          • rwh11385
            lance_entities
            • 18403
            word.
            Zionsville is a little town off of Indianapolis, and I've been there a couple times. (ZA that is, I've been to the town many times.....) Pretty much they dismantle cars and sell good, quality used parts. So, if they don't have one in stock, it's because they don't have one right now.
            But they helped me out when I needed a used caliper. :up:
            • James Crivellone
              Head Janitor
              • 6305
              I put a 1990 M3 Steering rack (airbag car) into my 86 325 without any issues, just had to remove the steering linkage (which pops off)
              I see no reason why it would not work
              • Charlie
                kid tested, administrator approved
                • 6686
                I believe that the 2.70 rack is from a 1.9 Z3 to be exact. Let me go back and search some archives, I think this came up on the Ti list.
                -Charlie
                Swing wild, brake later, don't apologize.
                '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                FYYFF
                • Digitalwave
                  is a poseur
                  • 6299
                  Airbag cars have completely different steering columns so it might be an issue. The pedals from a non-airbag car certainly didn't work in my airbag car (even though I don't have the airbag wheel anymore, its still a different steering column).
                  RISING EDGE
                  • James Crivellone
                    Head Janitor
                    • 6305
                    The flange at the steering rack is the same though, just unbolt, remove, and rebolt
                    I honestly didn't see any difference
                    • SpencerM3
                      • Aug 2004
                      • 114
                      All non-M Z3 cars have the same rack. The ETK P/N's are the same.
                      The 95 M3 and Non-M Z3's have the same steering ratio but the Z3's have less turns to lock. This is because the 95 M3 has a variable ratio and the Z3 has a linear ratio. So the 95 M3 is a bit slower off center and then quickens up. The Z3 has the same quick ratio off center.
                      I've got a Z3 rack in my garage going into my 95 M3. This should help with the slow off center feeling I get.
                      Keep an eye on ebay. I saw a Z3 rack go for $180.
                      • bmw4aaron
                        • May 2004
                        • 32
                        It's a direct bolt in, just gota loosen up the nut on the column, and pull out enough to make it mate up.
                        88 524td/5
                        98 540i/6
                        04 325xi
                        03 MB G500
                        93 Dodge D350 CTD
                        • SpencerM3
                          • Aug 2004
                          • 114
                          So what is so special about the kit that ZA sells?
                          I've heard that E36 racks will bolt right into an E30... so i'm assuming this isn't true? Is the "coupler" that ZA sells a special made piece?
                          • Schneider325
                            • May 2004
                            • 3818
                            why would u want to replace your steering rack to begine with? Newbie question sry
                            • rwh11385
                              lance_entities
                              • 18403
                              A changed ratio would make the steering quicker. So that less turns would have to be made to make the car change course.
