im going lower
  • kamotors
    • Nov 2007
    • 7102
    #31
    Originally posted by smonkbmw
    http://www.r3vlimited.com/board/showthread.php?t=106532
    it still sits the same 2 weeks later. i cant get it to scrape on anything. it doesnt even come close to the oil pan AT ALL. i live in a complex with some NASTY driveways and it wont drag anywhere. my suggestion is also while youre in there get yourself a kit for the control arms, CAB's, tie rods, sway bar links and of course new shock mounts front and rear. do it all while its out. youre not going to believe the difference it all makes when you do it all at once, its like a whole new car.
    you have bigger tires right?
    7speedshop.com
    • Fair!
      • Mar 2007
      • 202
      #32
      Originally posted by LivingLegend06
      Get coil overs. Drop it down in the summer and raise it up in the winter (if you must).
      +1 to this...
      Coilovers give you inifinte and corner-by-corner ride height adjustability, as well as additional wheel/tire room, the potential for shortened strut/shock bodies (which gives you more travel on a lowered car), and much more front strut/camber adjustability, if you have adjustable camber plates. "Lowering springs" are still gigantic things that eat up a lot of room inside the strut tower. But the cost for good monotube adjustable coilovers is a lot more than what the OP paid. :D
      Terry Fair - www.vorshlag.com
      Project Thread for the now-burned-to-a-crisp $2011 GRM Challenge Winning E30 V8 :(
      • smonkbmw
        Professor
        • Jun 2006
        • 4549
        #33
        lil bit yeah.
        • kamotors
          • Nov 2007
          • 7102
          #34
          hee hee hee
          7speedshop.com
          • kamotors
            • Nov 2007
            • 7102
            #35
            should be installed within the next week or two. i get the new shock mounts on the second and the spring compressor should come soon also. ill try to get it done before the 7th. so i can go for a nice drive on my birthday. any tips on installation?
            7speedshop.com
            • Danny
              • 14216
              #36
              Don't listen to the books about the rear springs.
              You just have to lower and unbolt the shocks and then pry it out carefully with a crowbar.
              • olskool
                • Mar 2008
                • 77
                #37
                I'm going with the same set up on my 90 325is. Let me know how the installation goes. Please post tips, recommendations and pitfalls to avoid during the install. Also, does anybody know what the going rate is to have springs and shocks installed?
                • PiercedE30
                  • Apr 2005
                  • 4220
                  #38
                  In the next 6 months or so I plan on getting rid of my H&R Race springs and going CO. I love my H&R Race springs. Drop is nearly perfect with an additional rear spring pad. I just wish that the front was slightly lower (maybe 1/2" or so). I may just pull out the front spring pads and see how it sits then.
                  My 2.9L Build!
                  • kamotors
                    • Nov 2007
                    • 7102
                    #39
                    okay i installed everything yesterday. pics will be here soon. i have 4.5 inches of ground clearance for the oil pan now.
                    7speedshop.com
                    • kamotors
                      • Nov 2007
                      • 7102
                      #40
                      heres pics
                      7speedshop.com
