Ok, after replacing both sides (complete tierods & ends) the steering wheel is off center by like 20 degrees clockwise. I thought that I measured and set the ends correctly, guess not. Is there a home alignment procedure that I can do to set them correctly? (I used to use a tape measure on my 89 VW GLI 16v to set 1/8" toe out, but only 1 tie rod was adjustable on that car.)
Thanks!
Chris
