GC camber plates popping
  • Van Westervelt
    • 9365
    V DUbn. Why dont you just rotate the actual bearing 180o? That would leave the strut at 0o and allow you to use all 4 bolts.
    • reelizmpro
      • 9486
      Wow you guys are nuts to do that to your strut towers for the sake of more adjustment. Anyway, I have heard reports of play in the bearings on the GC plates on a friends car a long time ago. Guess it wasn't an isolated incident.
      88 M3 - LACHSSILBER/SCHWARZE
      • DSP74
        • Nov 2007
        • 1121
        Originally posted by DSP74
        so you have to clearance the hole in the strut tower to get over -2.5 degrees camber?
        88 325is
        • rsafier
          • 164
          I was running IE Race plates and was told just remove two of the bolts (so only run 2 to hold the setting). I did no clearancing and could get -4* of camber no issues. Also had no problems with it slipping.
          SM 19 - Serial Destroyer of Cars
          Turbo '89 325i - It lives! Now the question is for how long?
          2SlowRcing.com
          • dlmrun2002
            • Apr 2007
            • 808
            I see the problem on the popping thanks to Lee.. The brass bushing that came with the shocks( not the GC camber plates ) is not under the camber plate. It is under the shock nut on top of the strut. So I guess I'll remove shock top nut, slide out brass bushing and install on top of the shock nut to sit up against the camber plate. Does that sound right Lee?
            Thanks.
            Doug M
            • 1fastcosmo
              • Apr 2008
              • 139
              ha i always figured it was something else in my front end popping.damn is it annoying
              • rwh11385
                lance_entities
                • 18403
                For those with seizing and popping of GC camber plates and haven't maintained the needle bearings...
                Problem solved. Cheaply and easily.
                • Dave
                  E30 RAT
                  • 11675
                  heetar, will you has those installed by october?
                  Current Cars
                  2014 M235i
                  2009 R56 Cooper S
                  1998 M3
                  1997 M3
                  • rwh11385
                    lance_entities
                    • 18403
                    it's possible.
                    confirmed location of fuel leak - 20 year old fuel *whatusedtoberubber* lines pouring out gas at fittings between filter and line to front. if that's covered soon, and trailing arm thing... maybe
                    would rather save for DP though
                    • Jean
                      • 18228
                      Wow! I've had the bigger inner washer crack but not the needle bearings. GC is not too far away so replacement parts aren't hard to get :)
                      • Hellabad
                        • 807
                        By the way, that picture is from a Ground Control Camber Caster plate for Koni struts, when it is used on a Bilstein. The parts are DIFFERENT. You can't do that, it will ruin parts. Its just like fitting a 325e head on a 325is motor. You can physically do it, but it was never intended to work that way.
                        Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                        Ground Control Gallery
                        The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                        • rwh11385
                          lance_entities
                          • 18403
                          Unless you sold Bilstein single adjustable strut inserts along with your Ground Control kit, those were from use with Koni struts...
                          Maybe this is GC's new customer approach of insulting customers and putting blame on them. Albeit unconventional, it is a more active strategy than putting on hold and forgetting to get back to them.
                          • Hellabad
                            • 807
                            Hey, mellow out. That post is not an insult. Maybe I got two usernames confused.
                            I have several pictures in my inbox that are exactly from people buying used GC plates for Konis and putting them on Bilsteins, and they look exactly like that because the bearings get pinched.
                            I believe this is what is described in post #20.
                            If I got two people mixed up, then I apologize.
                            Jay
                            • Brian D
                              • Mar 2006
                              • 832
                              nm, post overlap with Hellabad
                              1973 Bavaria
                              • Jean
                                • 18228
                                Jay,
                                What needs to be changed on the GC plate when one switches from Bilstein to Koni? Does it matter if it's koni SA or DA?
                                Thanks.
