Going to do a steering rack E36/mz3 swap this weekend, have the rack, adaptors, & modified high pressure line. Can I buy the low pressure lines in any auto parts store? What sizes do I need. Searching gives me info on the HP line, but nothing about the other lines. Thanks!
Steering Rack Swap - Help - What low pressure lines do I need?
Tags: None
I was able to bend the existing lines to work with the e36 rack. Did not need a lot of bending but had to do it with two pairs of channel T & G pliers and two sets of hands (fairly hard to bend).
Make sure to use new crush washers too...Comment
Yes you will need 2 new tie rod lock plates.
Crush washers are to complete the seal when hooking up the lines to the rack. Very important to use new ones to insure you get a good leak free seal. Go here for the part numbers for the crush washers (listed as copper seals, 2 different sizes)... http://www.r3vlimited.com/board/showthread.php?t=66247
Not sure if you will get those metal boot straps at the local auto zone. If they would have them they would likely be the ones that are a PITA to install as you have to feed the end through a slot and bend back over themself and crimp the tabs over it to lock in place. You can however use large zip ties and get them on really tight if you want too. Or the oem straps are premade and have to be installed before installing the boots and tierods and crimp together with the special tool made for this.Comment
