No air tools= suspension nightmare?
  • Gray S.
    • Jan 2008
    • 173
    Hey guys. I have been reading up on spring/strut swaps in preparation for my own DIY install and I'm a little concerned about the strut collar and nut for the front end assembly. Is this really going to be impossible to remove without air tools?
    I have seen so many DIYers install their own suspensions on here that it cant be that everyone has air tools. It must be possible to remove the front struts without a compressor.
    Any tips/tricks on how to get that collar and nut off?
  • StereoInstaller1
    GAS
    • 22679
    If you are doing new struts you should not be worried about the condition of the old struts when you are done...grab that bastard with Vice Grips!
    Closing SOON!
    Thanks for 10 years of fun!
    • etxxz
      • Feb 2006
      • 2085
      ...i don't think you can remove it with air tools to begin with...
      and btw air tools are not nec. i've dont just about everything to an e30 w/o air tools (s52, bushings, suspension, custom suspension..you name it; ive broken one)
      this is how you remove the collar nut:
      -remove strut from car
      -remove hat and then the spring, if you can't you fail...search.
      -get Big pliers: $10-20
      -put strut (w/o spring obviously) on a rim. bolt it. 2 bolts is enough.
      -stand on rim while you use the pliers to remove the collar nut.
      -be a man, try some more.
      -reverse assembly. Done!
      No more e30s for me.
      88 black BMW OBDII 332is dedicated track [sold]
      88 BMW OBDII bronzit 332is [RIP 03/08]
      91 BMW 325i [sold]
      86 Corolla 'Ae86' HB 20v trd [sold]
      http://youtube.com/watch?v=pTj7Hn9v5Rs
      • sticksdaman
        • Apr 2005
        • 2987
        It took me 26 minutes to do the front with the air tools....
        First time doing it... it is seriously worth it TRUST me
        Originally posted by ebelements
        Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
        • mattdk318i
          • Jun 2006
          • 3953
          i dont own a air tool and ive done everything too, Swaps,suspension,ect.....
          I agree with the above. Just make sure you add a breakover bar to that list.
          • Jean
            • 18228
            Air tools make the job go easier and faster.
            • etxxz
              • Feb 2006
              • 2085
              nobody's disagreeing...just saying they're are not necesary for this
              91 BMW 325i [sold]
              • Farbin Kaiber
                Lil' Puppet
                • 29502
                That's why I use electric tools.
                • einstein57
                  • Jun 2007
                  • 10780
                  Hear is a vdub secret. Spark plug socket with a long 1/4" ratchet going through the middle with an 8mm socket keeping the shock from rotating while you rotate the spark plug socket with a wrench.
                  www.gecoils.com
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    I'm trying to picture this...
                    • 2Big4a3Series
                      • Jan 2008
                      • 333
                      It took me 26 minutes to do the front with the air tools.... First time doing it... it is seriously worth it TRUST me
                      I agree. If you don't have air tools, rent them. I got a compressor, hose, and an impact wrench from the rental yard for less than $60 for the day.
                      • Aptyp
                        • 6584
                        Electric Impact.
                        The only way it will take 26 mins to do both sides is if you have the best of all world tools (wall mounted spring compressor, tie-rod/ball joint puller (lever kind), etc.).
                        • VAPORBLADE
                          • Sep 2006
                          • 1771
                          I used hand only. Though I have air too.
                          The collar nut was the hardest thing - but I put the disc and wheel back on the strut - then stood on the tire to remove the collar nut using a large pipe wrench. quick and easy.
                          '89 "is" = M technic II build mode.
                          • JGood
                            • Jan 2004
                            • 7959
                            I smacked a pipe wrench with a 10 lb sledge for 15 minutes to get the collar loose on a friends e34. We also had to drill the bottom of the strut tube and push the strut insert up through the top, then re-weld the bottom, as it wouldn't pull out from the top (the casing stayed and the shock internals popped out).
                            This is why it's stupid to say "you don't need air tools for this". Every car is different, who knows just how much rust is in there. Just because you haven't needed them doesn't mean nobody else will.
                            e30 restoration and V8 swap
                            24 Hours of Lemons e30 build
                            • Gray S.
                              • Jan 2008
                              • 173
                              Hopefully coming from a car that lived its whole life in Alabama I wont have any rust issues. I knew many people had to have done the swap without air power, but I've heard so many complaints about it and esp. this being the original suspension on the car it could be a bear to remove. Worse comes to worse I'll take the strut to a shop and have them blast it off in 5 minutes.
