Noises and clunking from Rear
  • etxxz
    • Feb 2006
    • 2085
    Had this in my previous E30 as well. I get noises from the rear like something was loose or broken when i drive over a rough road or hit a pothole, dislevel pavement and things like that.
    mods:
    560lb springs
    Koni shocks
    New OEM RTABS
    IE green subframe
    318Ti rear/5-lug w/ e30 e-brake assy/cables
    Things i checked:
    Rear Strut Towers: solid, mounts well bolted, no cracks.
    Differential: mounting bolts upwards of 150ft.lb. Driveshaft bolts are real tight too.
    Bushings: RTAB well, i used air tools on those when the subframe was off. Subframe IE Streets extremely tight.
    Things i notice:
    RTABS squeak sometimes when i lift and lower the car = normal
    With the car lifted and with rims/tires on, if i hit the tire with my arm hard enough i can somewhat reproduce the sound. But it isnt nearly as hard. It seems to be coming from inside the hub as if it was shaking.
    I have never done a wheel bearing, but they seem fine. I they don't make noises when i turn, drift, launch, e-brake and beat on them on a level surface.
    WHAT COULD IT BE???
    please help asap. I'm undergoing a 6.5hr trip tomorow..
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
  • Jean
    • 18228
    Checked your exhaust / shields / driveshaft ?
    • etxxz
      • Feb 2006
      • 2085
      my exhaust shields rattle under 500rpm but that's a different sound. this is more of a clunk than a rattle. Driveshaft huh, the CSB and guibo are perfect. Bolts are fine. sounds definetly coming from the very rear of the car
      91 BMW 325i [sold]
      • Mike@PureMS
        • Oct 2006
        • 221
        Any chance the spring is too short and becoming loose when the suspension droops?
        When you lift the car is the spring still tight on top and bottom? If it's loose when you lift the car in the air, it's likely the spring is rattling when you hit a pothole.
        Mike
        www.purems.com |Temecula, CA | 866-397-5487
        • etxxz
          • Feb 2006
          • 2085
          its a coilover and is not tight, but its impossible to take out w/o removing the shock...now, what about why it makes the noises during rough road...its not lifting...huh
          91 BMW 325i [sold]
          • funcrew
            • Jun 2007
            • 1223
            A long shot, but check the fluid level in your diff. LSD will clunk like a bastard if it gets low on oil.
            "If the sky were to fall tomorrow, the tall would die first."
            -Dr. Paul Forrester
            Do I LOOK like I need a psychological evaluation???
            • craz azn
              • 746
              Check your rear brake pads. Clinking in the rear caliper carriers? Mine does a similar noise too, but I'm too lazy to take the wheel off to fix it lol.
              Rippin' Proper | Youtube | Vimeo |
              • qbuilt
                • Jun 2007
                • 94
                Thats probally it. I had the same sound before. Only occuring over quick/sharp little bumps. Found the brake pads to acually be seperated from the metal backing of the pad. However I have also seen the caliper slides get all worn out and dry and make a very similar sound. Just grese the crap out of everything with a good brake lube or a high temp antiseize. Should shut it up.
                If that doesnt fix it maybe you have something going on within the ebrake assembly(seperated shoe, broken spring,etc...)
                Also check the centercap on your wheels, if you have center caps that is?
                • kenika65
                  • Aug 2007
                  • 1336
                  exhaust tip hitting rear valance
                  1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
                  1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
                  • japspecvr6
                    • Apr 2005
                    • 602
                    Im having this same problem as well.......
                    M52 |S52 Cams|E36 Rack Swap|GC Coilover Kit |. . . . . . . . . More To Come
                    • etxxz
                      • Feb 2006
                      • 2085
                      def not exhaust.
                      check it out. crazn and qbuilt are on the right track. Found out my 5-lug ti rear doesnt have the brake pad holding spring/metalbracket thingy. I have new sliding hardware on the rear calipers but the missing "pad-holder" may be the problem. The noises cease when i step on the brake. This leads me to believe that everything else is okay and this is brake related.
                      for those interested. part #
                      e30 (88is) - 34211153199
                      318ti - 34211157046
                      91 BMW 325i [sold]
                      • BimmerTom
                        • 255
                        Good info, thanks for looking into this. I have the same problem, and my Hawk HT-10's rattle like no other.
                        Tom
                        My new blog site: http://www.tomperso.com
