Installing stock rear springs
  • Nic01101011
    • Jan 2008
    • 1549
    hey
    I remember taking off the stock rear springs was easy - unbolt the sway bar, shock, stand on the hub, and you could pull it right off.
    unfortunately Im having a tough time doing the reverse - any tips?
  • tjts1
    • May 2007
    • 1851
    You need springs compressors. Anything shorter you can do it without.
    • E30_fiend
      • Apr 2006
      • 7348
      A big pry bar and some balls. Get the spring set on the trailing arm and then get the top in as far as you can and then set the pry bar between the top of the spring and the upper spring perch. Push the pry bar toward the ground and at the same time push forward on the bar to slide the spring into place.
      Its rather self explanitory with the pry bar.
      Good luck.
      Taylor
      • Nic01101011
        • Jan 2008
        • 1549
        thats the thing, i dont see how you can use a compressor with the rears
        I guess ill just try prying it in
        • E30_fiend
          • Apr 2006
          • 7348
          I don't see how you could use a spring compressor back there either. The compressor itself would get in the way. Haha what I have done before was set something really heavy on them like a big box or something and while they were compressed by the box I got a thick zip tie on each side and got them zipped as tight as possible and then did the same to the other spring. They were then small enough to set in between the frame and the trailing arm. I lowered the car down slowly and once they were positioned right I cut the zip ties off of the springs. Pretty eat and quick
          Taylor
          • xLibelle
            • Aug 2004
            • 2673
            there is like one way to use the two-piece spring compressor. I believe ive had to locate them roughly 33 degrees appart from each other... not entirely safe situation so wear eye protection!
            You'll have to work one of the screws with a simple wrench too. Not to mention, working them pretty evenly.
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              it can be done, i've done it. go to autozone and rent a spring compressor, it comes with two spring compressors, so just use only one. Takes patience but you can do it
              • g22
                • 274
                just use a pry bar and be done
                • tonytony
                  Knee deep in poopie
                  • Jan 2004
                  • 3498
                  rent a spring compressor, it's FREE no hassle
                  • deutschman
                    • May 2008
                    • 5958
                    pry bar...
                    its the way to go
                    • tonytony
                      Knee deep in poopie
                      • Jan 2004
                      • 3498
                      it's easy and it's safer than a pry bar, why risk anything popping out of place and nailing you in the face? I should be a lyricist
                      • Kingb
                        • 928
                        Just put the car on a jack stand and use a jack to raise up the trailing are or put a block under the TA and lower the car on it. It will compress the spring enough
                        Originally posted by Nicademus
                        My car beats off to that car. :bow:
