Broken coil spring?
  • Griffin
    • Dec 2008
    • 68
    Broken coil spring?
    How does one break a coil spring, exactly? The car doesn't seem like its been taken off any jumps, but the front driver's side spring is broken. Methinks its time to replace them all with some not-too-slammed sport springs.
    Neal Mulcahy - 84 318i
    LRRS/CCS #427 ECK-Racing 2009
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
  • DRTSRFR
    • May 2008
    • 1836
    If you're in an area using salt to treat the roads, It only take a small chip in the powder coating to start the corrosion process. I've seen springs break after only a year or so of use in areas with harsh winters.
    Suspension tips here...
    http://www.r3vlimited.com/board/album.php?albumid=757
    • JGood
      • Jan 2004
      • 7959
      I remember there was a bunch of people breaking e46 rear springs. That's not something I'd want to happen mid corner...
      e30 restoration and V8 swap
      24 Hours of Lemons e30 build
      • erik325i
        • Jan 2005
        • 3567
        Yeah, I've seen an aftermarket e46 m3 rear spring break in half. Can't exactly say why though. We don't have harsh winters here in Cali so no salt on the roads.
        Erik
        • Knockenwelle
          • Jul 2008
          • 395
          Inferior material used in the spring wire can cause localized weak spots. Read: stress concentrations.
          Mike
          '91 325i track car. Mostly...
          • gearheadE30
            • Jun 2007
            • 3734
            Also, when you consider how much stress the springs are under and how much they have to flex, that metal has a lot of fatigue. The e46 springs are just weak; though. that's actually a pretty common issue for those cars, even dd ones.
            Project M42 Turbo
            • IveGotIssues666
              • Oct 2006
              • 517
              Yeah the E46 Xi springs tend to break alot, I've replaced quite a lot.
              Jared
