Sway bar size questions
  • HotRod
    • Sep 2004
    • 4
    Interested to find out what size of the front and rear E30 Sway bar/anti roll bar
    AC Schnitzer -- mm?
    Eibach --mm?
    RD --mm?
    TQ.
  • riverdale21
    • Mar 2004
    • 786
    Eibach: front 20mm rear 16mm
    Racing Dynamics (adjustable): front 22mm rear 19mm
    AC Schnitzer: front 20mm rear 16mm
    Suspension Techniques: front 22mm rear 19mm
    H&R (adjustable): front 22mm rear 18mm
    I might be missing a couple of companies though.
    All sizes are for non M cars.
      • 34839
      Don't forget, Ireland Engineering! 22mm rear, 25mm front :shock:
      • aaron_silva
        • 1785
        Cabrio Front- 21mm
        M3 Rear- 14.5mm
        These are cheaper than aftermarket companies.
        Aaron
        • demlotcrew
          • May 2004
          • 297
          even better, 19mm front and 14.5 rear, too much on the front causes heavy understeer, which is what i was experiencing with the 21mm front arb and 14.5 on the rear, swapped round to the 19mm and it really made a difference, the car rolled alot more but it didn’t understeer, so its up to you and what you want the car too do. Remember less body roll means less drifting, but its best to correct this with harder spring than ARBS, but then the ride quality is gone, so its a compromise really.
          HTH
          Andrew
          Andrew AT E30zone.co.uk | H23-is | S14
          • Rob
            • 8166
            stock front is 19mm, no?
            BEERTECH
            • demlotcrew
              • May 2004
              • 297
              im pretty sure its 20mm stock, could be wrong long time since ive worked with them.
              • MattM20
                • 641
                i think the front M3 bar is 19mm and the 6cyls have 20mm; however, i'm not sure about the compatibility of a M3 front bar on the front of a non-M e30 due to the different pickup points
                • aaron_silva
                  • 1785
                  The M3 bar mounts up to the non-m pick-ups.
                  Aaron
                  • Rob
                    • 8166
                    using non-M end links I would presume
                    BEERTECH
                    • aaron_silva
                      • 1785
                      correct.
                      Aaron
                      • chesster6969
                        • 321
                        So whats the stock size sway bars for the front/rear of a 325i,325iS, 318i, and 318iS?
                        • Rob
                          • 8166
                          318is, 325is: 20mm/12mm F/R
                          m10 318i: dunno about the front, but no rear
                          someone correct me if i'm wrong
                          BEERTECH
                          • chesster6969
                            • 321
                            Im assuming the sways for regular i models are the same for iS models?
                            • ///M Powered
                              • Jan 2004
                              • 1109
                              Originally posted by aaron_silva
                              Cabrio Front- 21mm
                              M3 Rear- 14.5mm
                              Aaron
                              aaron is the cabrio sway a 12 mm ( rear)?
