Help! putting in my rear suspension and have a diff problem!
  • steinbachphoto
    • Aug 2007
    • 914
    Alright so for putting in the rear springs I need to lower the diff, But I can only get it to go down about an inch and a half, but in the pic on Pelican Parts, they have theirs down at least 3 inches. Is there something I'm missing?
    http://www.steinbachphoto.ca
  • Thor
    • Jan 2008
    • 31
    Silly question, I know... but do you have the parking brake on?
    • e30frosh
      • Dec 2004
      • 2170
      Lift car, remove wheels, remove calipers, unbolt swaybar, unbolt struts, unbolt diff, lower diff, add a little downward pressure to trailing arm, rear springs should fall out.
      Installation is the reverse of removal.
      Every day I wake up we drink a lot of coffee and watch the CNN
      Every day I wake up to a bowl of clover honey and let the locusts fly in.
      Lobsterbacks attack the town again
      Wrap all my things in aluminum
      Beams of darkness streak across the sky
      Pink rays from the ancient satellite
      Every time I look out my window same three dogs looking back at me.
      Every time I open my windows cranes fly in to terrorize me.
        That's way too much to go through.
        Get the rear of the car on jackstands, remove the wheels & lower shock bolt and disconnect the sway links. Use a spring compressor to reduce the height of the springs and slide them out. Compress the new springs and slide them in.
        • e30frosh
          • Dec 2004
          • 2170
          This was assuming that the OP had no spring compressors. Besides, using the compressors would take longer, believe it or not.
          • E30SPDFRK
            • 5695
            If you're not saving the stock springs, just cut them in half while they're still on the car.
            Byron
            Leichtbau
            • steinbachphoto
              • Aug 2007
              • 914
              i was able to push the trailing arm enough to get the springs out, I was just confused because my diff wasn't as low as the one shown in the article on Pelican Parts.
              FWIW i put in hr sports and bilstein sports
