Sway Bar removal
  • neogenetik
    • 38
    Sway Bar removal
    Hey
    i need help takin out my rear sway bar on my cabrio
    i took off all the bolts just wondering how to take the whole bar out?
    any suggestion?
    thank you
  • e9nine
    • 1890
    Detach the end links and wiggle it out. If you have afternarket springs, its kinda easier...of course you want to take one wheel off so you can see what you're doing better.
    Have fun :twisted:
    • Bill 84 318i
      • 1600
      Yeah, and you'll probably have to take one spring out too.
      • AdamF 88iS
        • 2051
        Yea just take out the passengers side wheel and spring, and pull the link off the drivers side and it'll slide out.
        Adam Fogg- '88 M3
        Common sense- It's the new 'gifted'
        • ///M Powered
          • Jan 2004
          • 1109
          Do you need to take out the spring and wheel to install? ( Just as a heads up)
          • Bill 84 318i
            • 1600
            It's a huge PITA (if not impossible) to either take it out or put it in with the spring in.
            It only takes 5 minutes to get the spring out/in. Take it out.
            • ///M Powered
              • Jan 2004
              • 1109
              That's what i needed to hear, thanks.
              • LikeCDoos
                • Jan 2004
                • 2522
                How do you remove/install on the front end?
                • Digitalwave
                  is a poseur
                  • 6297
                  Easiest way for me was to disconnect the inboard and outboard links, and then remove my control arm bushing brackets and just swing it out that way.
                  RISING EDGE
