m3 sway bar links
  • kylebes1
    • May 2004
    • 2804
    m3 sway bar links
    The e30 m3 can use a smaller diameter sway bar since it connects to a higher part of the strut right?
    what would be involved in setting up a regular e30 sway bar like this, or is it the same shape?
  • Jordan
    • 12913
    weld the tabs onto the strut housings. TMS sells them.
    The bars use all the same mounting points and are interchangable.
    https://mtechniqueabs.com/
    • kylebes1
      • May 2004
      • 2804
      thanks
      • rs4pro3
        • 5808
        Ground control also has the tabs for $8 each.
        I have the m3 links on my 88 325is, and i'm currerently running a 18.5mm eta bar, instead of the 21mm cabby bar I had on it before I swapped.
        85 325e 2.7 ITB'd stroker
        • kylebes1
          • May 2004
          • 2804
          which do you like better?
          • rs4pro3
            • 5808
            I swapped to the 18.5 as the 21 had to much understeer. I have a 20mm IS front bar I may try sometime but right now with a stock rear bar the 18.5 with m3 links is about perfect for my car.
            • kylebes1
              • May 2004
              • 2804
              i need one for the rear as well, the 84 318i does not have one.
              • rs4pro3
                • 5808
                I have 3 12 mm rear bars in the garage if you want to buy one for cheap.
                That made a huge difference on my 85 318i when I had it.
                • Jordan
                  • 12913
                  Does the 318i have all the needed tabs and threaded holes to mount a stock rear swaybar from a 325i?
                  • kylebes1
                    • May 2004
                    • 2804
                    good question
                    • rs4pro3
                      • 5808
                      Yes my 85 318i did, and Bill has added one to his 318i also.
                      The hardest part of the whole job is getting the sway over the diff.
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        Yeah, it's a bitch to get the rear sway in. I took both wheels off and slid the whole bar through one of the springs and straight over it. It wasn't too hard to get it in that way, but it took me 45 minutes to figure out the best way to get it in.
                        Originally posted by Gruelius
                        • rs4pro3
                          • 5808
                          On mine, I just pulled the passenger wheel, it helps to pull the links off and just slid in the bar then install all the hardware.
                          I can't remember if I converted my 84 318i as well or not :?
                          • M-technik-3
                            • 18946
                            Wasn't to hard on a lift. I added one to my 85 320i made a big differance.
