Question About E30 Steering
  • Leonstt
    • Feb 2019
    • 81
    Hi guys, I have a problem with my E30 steering/handling. Actually, I have 2 problems which I'm not sure whether they are related.
    The first problem:
    During braking, I feel that my car is pulling to the left. I haven't done any wheel alignment since I changed my springs and brakes. When I'm driving straight, the steering wheel position is pointing slightly left. But the car is not pulling to either direction. Only pulls to the left during braking.
    Second problem:
    I hear slight knocking coming from the steering rack. When I jack the car up and wiggle the front right wheel, I can here a knocking sound from the right hand side of the steering rack (please see picture attached). It feels like there's a play in the right hand shaft. The left hand side is nice and tight, no knocking sound.
    Note: all the bushings are new and suspension (springs and shocks) are also new.
ID:	9923140Do you think these two problems are related? Can the first problem be solved by doing a wheel alignment? Please advise Thanks guys
  • theroundcow
    • 183
    might as well get under your car, pull the boot back, and make sure your tie rod assemblies are on tight. thats basically exactly where your suspecting the issue.
    • tomstin
      • Mar 2015
      • 568
      Originally posted by Leonstt
      The first problem:
      What did you replace when you did the brakes? Replace just the pads? If just the pads, I would suspect when you pressed the caliper piston back it's jammed and time for rebuilt calipers.
      2004 525i Manual - 1985 325E Coupe Manual
      • jeffnhiscars
        • Jun 2011
        • 6011
        I'd check to see that all suspension bolts (ie tie rod ends and CA) are tight and the that your strut mount isn't damaged.
        Alice the Time Capsule
