16 inch wheels spacers
  • madformx5
    • 817
    I am interested in knowing what width of wheel spacers and tires anyone on here is running with 16 inch wheels with a 40mm offset. I am thinking I want 15mm spacers but I thought I would ask before I ordered anything. I would also like to know if people are running hubcentric spacer or the plastic hubcentric rings with spacers.
  • theox69
    • May 2008
    • 1732
    how wide are the wheels?
    and what's your suspension setup?
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
    • madformx5
      • 817
      Stock suspension right now but I have some bav springs and bilsteins to put on soon. I want to change the control arms and tire rod ends when I install them but I still have to order the suspension parts so it will be a bit before I do install them. The wheels are 16x7. Sorry I meant to put the wheel width.
      • theox69
        • May 2008
        • 1732
        You should be fine with 15mm spacers.
        Post over on Mystikal's wheel/tire thread if you want expert advice.
        • madformx5
          • 817
          Thanks. Do you have 16 inch wheels on your car?
          • theox69
            • May 2008
            • 1732
            I had 15".
            But I'm selling them soon -- I already bought (and have in my posession) 16x8" et14 that should be really flush with the fenders.
            I'll be putting them on soon enough.
            • E30SPDFRK
              • 5697
              I'm running 16x7 et35 with 10mm spacers, so they are the same final offset as the wheels you want. Running a 205/45 with no issues at all.
              Byron
              Leichtbau
              • theox69
                • May 2008
                • 1732
                You could probably run 225/45's without any rubbing issues.
                I'm pretty sure that's the tire of choice for whoever has Remembers.
                • h82crash
                  • 127
                  To get the spacer hub the perfect size for the wheel they will need to be custom made, like $150 a pair. The hub ring should be fine on the 57.1mm hub, the likes from H&R or BMP.
                  "Life is hard...it's a lot harder if you're stupid."
                  Tom
                  72 2002
                  87 327i
                  88 525i
                  88 535i
                  03 530i
                  • madformx5
                    • 817
                    I had not thought of 225/45/16 before. I have been looking at 205/50/16 or maybe 215/50/16. I will have to do the math to see how tall they are.
                    • madformx5
                      • 817
                      The stock size is 195/65/14 = 23.980
                      optional sizes are 205/50/16 = 24.070
                      215/50/16 = 24.466
                      225/45/16 = 23.972
                      b/c I'm curious 225/50/16 = 24.858
                      The 225/45 is closer than I thought it would be. Have any of you guys ran this size tire before? Does it clear in the front of a lowered car? I'm guess my car is going to go down about 1.3 to 1.5 inches with the struts springs and shocks on. Looks like the 225/50 would be a little to tall.
                      • theox69
                        • May 2008
                        • 1732
                        225/50 is too tall.
                        Go with 225/45 for your car.
                        The offset is high enough so you may not even need fender rolling and you probably won't rub on your struts.
                        I'll be running 215/45 on my wheels, only because the offset is much lower.
                        • Mystikal
                          Wheel Fitment Expert
                          • 9602
                          225/45/16 will be fine with 15-20mm spacers. I've run it at ET25 16x7 without any fender rolling and room to spare.
                          • madformx5
                            • 817
                            Cool thanks guys.
