16x7 +35....How much spacer? (I searched, and I suck I guess)
  • Works243t
    • Jun 2007
    • 452
    I searched, and there are so many threads with so many pages, its daunting.
    That being said, how much spacer TO LOOK GOOD/RIGHT, not just to clear the inner bits? The wheels are Konig Remembers and the deal is just too good to pass up, unless I will be spending an arm and leg on spacer/tires etc.
    Thanks in advance.
    1987 325is.
    E92 M3...
  • lov-e30
    • 16548
    I would say 15mm front and 20mm for the rear and your set.
    @IRON-E30 aka Edwin:D
    • Works243t
      • Jun 2007
      • 452
      Thank you sir.. Just curious if that is from calculation or experience?
      I was thinking about 20mm myself since factory is ~15mm and these are 35..
      E92 M3...
      • daniel
        • 6703
        may i ask what "deal" you are getting on these remembers? brand new remembers with the correct offset are like $550 for all 4.
        http://instagram.com/dslovn.drives
        • Works243t
          • Jun 2007
          • 452
          $300 so not amazing, but I'm thinking I can get them a bit cheaper. Tires are no worries, I know a distributor, so ~$400 with spacers (I have some tires now) for a perfect set of remembers...
          What are your thoughts..
          E92 M3...
          • 416stroker
            • May 2008
            • 2448
            it would be cheaper to buy the right offset spacers are expensive, Like 300 for a full set.
            84 318I Delphin RIP
            87 325IS delphin 24v Sold
            89 325 Alpineweiss
            • Works243t
              • Jun 2007
              • 452
              Probably go that route then..
              Thanks guys.
              E92 M3...
              • 416stroker
                • May 2008
                • 2448
                Thanks guys.
                Ya I think most good hubcentric spacers are like 100-150 for Two.
                84 318I Delphin RIP
                89 325 Alpineweiss
                • h82crash
                  • 127
                  Some good HC spacers from BMP for about $65 a pair shipped, just got some myself and they are very high quality Italian made.
                  "Life is hard...it's a lot harder if you're stupid."
                  Tom
                  72 2002
                  87 327i
                  88 525i
                  88 535i
                  03 530i
                  • yberther
                    • 1246
                    aren't they just turned down al to a certain id/od??
                    Flickr
                    Originally posted by Indecline06
                    For some reason, when I get super duper ultra stoned... The M30 motor reminds me of big bird from sesame street.
                    • h82crash
                      • 127
                      Sort of..The BMP ones are billet then drop forged and machined. Even cheap Chinese ones are 40 bucks and then you have to find the right hub ring to fit your wheel because hub centric boss is usually larger than the ID of the spacer.
                      Tom
                      72 2002
                      87 327i
                      88 525i
                      88 535i
                      03 530i
                      • JGood
                        • Jan 2004
                        • 7959
                        FYI, My 16x7 et38 Mille Miglia MM11-2's on 205/45/16's clear the insides with 10mm spacers. That's just to clear with some room to spare, not to look "cool". so I'd agree with the previous statement that getting to ~et20 would be good with 15mm or 20mm spacers on the et35's. I'd also agree with the statements that it's better to get wheels that fit :)
                        e30 restoration and V8 swap
                        24 Hours of Lemons e30 build
