Cracked rim can it be fixed?
  • parkerbink
    • Jun 2004
    • 10138
    Hit a "smart boulder" that chased me across four lanes of road.
    Wheel gurus do you think this can be fixed? Place I got them from fixes, refinishes rims says they have a heli-arc & can fix all but the worst cracks.
    Discount tire says the damage to the tire is cosmetic, what do you think?
  • mikegar
    • Aug 2005
    • 523
    get some duct tape and jb weld and youll be set..........
    Originally posted by Ferdinand
    I carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
    DIVING BOARD DIVISION DIVISION IDIOT
    • E30SPDFRK
      • 5707
      Easily fixable wheel. Can't tell the condition of the tire without seeing it in person, but it doesn't look too bad.
      Byron
      Leichtbau
      • parkerbink
        • Jun 2004
        • 10138
        Its not losing air, I did not know I hit it in back until they removed the front one & said it was bent at the hub so went to put this one in front & said it could hurt the tire if left on in this condition.
        Thanks
        • e30_325es
          • 1249
          If you peel the tire back, can you see strands of thread? If so, it's trashed. If not you could be ok. Can't guarantee w/o seeing it in person.
          • parkerbink
            • Jun 2004
            • 10138
            No matter how hard I push at it I cannot see anything but sidewall, it has lost no air.
            It is a -600 mile RE960 Pole position, I hope it is fine. I'll know after I talk to the adjuster if I am dealing with it out of pocket or filing a claim at which point it will come off the rim and I'll know what is going on inside.
            Thanks
            • parkerbink
              • Jun 2004
              • 10138
              Tire is off, rim is being fixed. Looks like I got lucky tire wise.
              • parkerbink
                • Jun 2004
                • 10138
                Rim is fixed, glad it cracked in back.
                Tire looks ok too.
                • parkerbink
                  • Jun 2004
                  • 10138
                  Now on to the the front one that is bent at the hub.
                  • asubimmer
                    • 6482
                    how much did that cost ya? I need to have a wheel repaired. I bought it that way, but sure makes a set cheaper ;)
                    • parkerbink
                      • Jun 2004
                      • 10138
                      90.00. These guys refurbish rims, I got the set from them for 100.00 per rim. They quote 60-90 depending on the damage.
