Running 16x9 Borbet Ts (et15) with 215/40 R16 tires.
10mm spacer on front
20mm spacer on rear
AGRESSIVELY LOWERED.
I'm about to fix the rear geometry by replacing my subframe with one that has the toe/camber kit welded on. I want to get a little more life out of my tires, so I'll probably fix the camber a bit. I'm afraid that if I do that, the 20 mm spacer will be too much and I will have some fender interference (already rolled). There is some interference already when really loaded up, but that's not very often.
So my question is: What size spacer should I get? Is it as simple as taking 5mm out and I'll have that much more clearance? Or is that enough? I keep meaning to look under the car and see how much room I have on the inside, don't want to clear interference one way, and start some the other...
I'm going to get custom spacers made (again) so I want to know what to tell Fred.
20mm spacer on rear
