Rays Engineering CE28N
  • Massimo
    • Jan 2008
    • 3207
    I found that the Rays Engineering CE28N wheels will fit an E30 the 8 spoke design comes in 16x7 et20 4x100
    ホイールメーカーのRAYS(株式会社レイズ) 。レーステクノロジーとメイドインジャパンの精密さを融合した高性能ホイール。F1で鍛えたノウハウで、全車種対応の軽量・強靭なデザインを提供しています。
    My only concern is that i can't find out what the hub diameter is, dose anyone know and dose that really matter or is there a way around it?
    Thanks Guys
  • wildstoats
    • Sep 2007
    • 896
    As long as the center bore on the wheel is larger than the e30's center bore you should be solid. Just need to get some custom center bore adapters made.
    • e30guydownunder
      • Jul 2008
      • 874
      Centre bore is more than likely 63 or 73mm. Hub centric rings are available for either and are accepted as a good solution for making wheels fit a wide variety of cars these days. Rays will probably even provide them with the wheels.
      Good find :)
      - Chris
      Project M42 - 255 @ 19 psi
      • Massimo
        • Jan 2008
        • 3207
        All right cheers guys better start saving now about $2000 AUD should be sweet though.
