Is 225/40 too big for a 16x9? (rear)
  • svn2002s
    • Sep 2004
    • 486
    Anyone running 225/40 instead of 215/40 in the rear?
  • matt
    • 3732
    Are you serious? People run 235/40s on 7.5" 17" wheels all the time.
    Or are you concerned about rubbing?
    • daniel
      • 6703
      225/40 is too small for a 16x9 in my opinion.
      http://instagram.com/dslovn.drives
      • theox69
        • May 2008
        • 1732
        Depends on the offset, and your willingness to roll your fenders.
        you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
        • Asbradley21
          • Jun 2008
          • 1938
          Way too small. I run 225 50's on a 15x7
          S54B32 swap in progress. Status: Getting There
          • E30SPDFRK
            • 5716
            Not at all for the rear. You will need a little bit more rolling, but height wise they will fit fine.
            Does anyone even make that size?
            Byron
            Leichtbau
            • svn2002s
              • Sep 2004
              • 486
              Well, it looks that 215x40 is the tire of choice for the 16x9 (et15) euro look. Toyo makes 225x40
              • balooshinakus
                • 511
                I wouldn't call stretched tires a euro look personally bu I guess that's personal taste, I'd do 245 width tires on a 9 inch rim
                • E30SPDFRK
                  • 5716
                  Actually 205/45's are the preferred stretch tires for 9's. About the same amount of stretch as a 215/40 but a bit taller so it fill the wheel wells better.
                  Byron
                  Leichtbau
                  • E30_80Y
                    • 145
                    would that clear the fenders for 16x9 et10 with the 205/45?
                    • mcr_driver
                      • 4491
                      215's should be fine for most drops i think 225 might require a smaller sidewall for clearance but i think it could work...
                      • Wh33lhop
                        • 11705
                        Stretched tires originated to conform to a european law (I don't remember where in europe) that stated the tread needed to be contained within the fenders. So people kept the tread in the fenders and poked the sidewall out.
                        I see it on both japanese and european cars, but the roots are european.
                        paint sucks
                        • Massive Lee
                          • Sep 2006
                          • 6785
                          too small in overall diameter (should be 45 aspect ratio), and too narrow in width to fit a 9" rim
                          Lee
                          massivebrakes.com
                          • bmws50b30
                            • Aug 2005
                            • 1151
                            225/45/16 on 16x9 ET 24
                            1991 330is
                            • E30SPDFRK
                              • 5716
                              Lee
                              How do you figure they are too skinny? 225mm is almost exactly 9 inches wide.
                              Byron
                              Leichtbau
