Question about Mazda Miata fitment wheels
  • Jand3rson
    • 37587
    I'm pretty sure I already know they answer to this, but I just want to double check.
    Is it correct that Mazda Miata's have the same fitment as the E30? Does this mean I can look for wheels for a Mazda Miata on TIreRack and they will fit the E30? I have no issues using spacers, so offset is not a problem.
  • egk2
    • 2426
    1995 miatas are 4x100 but have a different center bore, you could possibly use some centering rings and spacers to make it work.
    • Rob
      • 8166
      miata center bore is 54.1mm, so they arent a direct fit.
      BEERTECH
      • E30Driv3R
        • May 2004
        • 1169
        What is the E30's center bore?
        Dan Zickel
        1995 M3, 1991 318iS, 1987 325iS
        • Jarvis
          • 2132
          57.1 IIRC
            • 37829
            So are spacers needed or just some hubcentric rings? [Newb at this stuff]
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • Rob
              • 8166
              miatas usually use ~et35 offset wheels, so spacers would be needed. I dont know if they make spacers iwth the correct hub stuff though..
              BEERTECH
              • Digitalwave
                is a poseur
                • 6293
                You can't put a rim on our cars that has a smaller center bore though. Hub centering rings are for rims that have a larger center bore than what we have.
                RISING EDGE
                • Mystikal
                  Wheel Fitment Expert
                  • 9602
                  Just use an MKII VW.
