Where in Western WA can I fill and redrille 5x120 to 4x100 wheels? Thanks
e39 style 5's filled and redrilled???
"i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleTags: None -
Lots of shops do it. Just google and make a few phone calls. I think factory direct does it too. -
Thanks, by the way, your e30 has same wheels I'm trying to put on, did you redrille them or converted to a 5 lug? Which is the best route? Thanks again"i love vee tek, its a wonderful sound when you driving right by it"
If you bought anything from me, please leave a feedback here: http://www.r3vlimited.com/board/show...ghlight=drulleComment
I did it the right way and got e30 m3 suspension.
Trust me dont get them drilled. Find a e30 m3 suspension somewhere and use that. Then you can have a larger selection of wheels you can run.Last edited by e30s52; 09-22-2009, 06:49 PM.Comment
E30s52 has a 5 lug swap.
Make sure the back surface of the wheels are flat. It makes it very difficult to fill and drill if it is not. About $260 seem to be average on the fill and drill.-tim
-Coining hip terms since 10/9/03Originally posted by JordanI like the stanceComment
You're also going to need hub centric rings either way.
Style 5's = 74.1 mm
E30 M3 hub = 72.56 mm
E30 hub = 57.1 mm
'91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
'87 535i - Vacuum brake conversion [SOLD]'93 525iT - 5-speed swap - 320k and counting'09 328xi - 6-speed
I have a GB for custom adapters that we could make hese hub centric to the car and the wheels without needing to do a suspension swap. Check it out and see if it's something I could help you with.
Style 5's are one of my fav wheels.
-RobNeed Custom spacers and adapters?
PM for informationComment
