Ronal Ls's Rubbing
  • BlackE30
    • Sep 2004
    • 605
    Ronal Ls's Rubbing
    I have ronal ls's on es100s, there rubbing in the front when I try to turn (U turn) I dont think they should be rubbing since I am running the same tire size 205 55 15s as on my euro baskets. People who have these, do you have rubbing probs as well?
    Jeff
  • Skafrog
    • 1732
    wow, I run 225's and have no rubbing issues, except for the inner fenders when they were still in.
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
    • trent
      Re: Ronal Ls's Rubbing
      Jeff
      Euro baskets are only 7 inch wide, not 7.5
      • M-technik-3
        • 18946
        Yea so 0.25 goes to the inside. the offset on these are ET26? or ET25? Do they rub both directions? Or only one way?
        • Brew
          • 3060
          Well, you shouldn't have any rubbing with those wheels/tires. Has the car ever been in an accident?
          '91 318is
          • jweb
            • 959
            Same here
            Jamie Webster
            '89 325is - sold :(
            '96 Miata - sold
            '01 M5 - sold
            '02 Civic Si
            • MattM20
              • 641
              Same here
              same here, and i didnt even need to roll my fenders. greg, the offset on the current LS's are et25
              • ZiMMie
                • Jun 2004
                • 968
                will 235's in the rear rub on the ronals?
                www.stancefactory.com
                • 87 325iS
                  • Jun 2004
                  • 277
                  Too much sidewall? Just a guess, cause don't most people run 50s?
                  Amber Fire Pearlcoat 2000 Dodge Dakota R/T
                  Schwarz 1991 BMW 535i [Daily Driver]
                  Dark Currant Pearl 1996 Acura Integra GS-R [For Sale]
                  Orientblau Metallic 1994 BMW 740i [Sold]
                  Alpinweiss 1987 BMW 325iS [Junked]
                  • M-technik-3
                    • 18946
                    Check to see if you have hanging plastic. Maybe it needs tiddying in your wheel wells. Or just don't pull such a drastic u turn.
                    On a side note what are you running for tires?
                    • e9nine
                      • 1890
                      I'm with greg on checking your wheel well lining/mudgaurd thingymajigs and no need to crank the wheel to FULL lock and hang on to the wheel like you're in the gym when doing u-turns ;)
                      • MattM20
                        • 641
                        probably not but i dont know if such a tire (235/50/15 or 235/45/15) exists, and if they do exist there will be a very small selection
                          • 34839
                          no, 205/55-15 is a normal E30 size.
                          • powerslave
                            • Dec 2004
                            • 11
                            I ran the same size tire on mine for awhile, no problems here. Now I run 225s and still havent rubbed once. Is your car lowered?
                            '94 325is
                            '91 318is
                            '87 325is
                            • Mystikal
                              Wheel Fitment Expert
                              • 9602
                              Basic fact, something is bent and/or not the shape it is supposed to be. Have your front end inspected.
