Rubbing... sugestions please
  • Uber E30
    • 1409
    Im running 225/45/16's on 16x7.5 et25 wheels. My rear rubs like crazy under moderate acceleration, or going up hills. My fenders have a slight roll, do i just need to roll them more or should i go with 215/45's?
    -Alex
  • bmws50b30
    • Aug 2005
    • 1151
    i have no answer to your problem but with et25 you shouldn't have any rubbing issue. i have the same size tires and wheels.
    1991 330is
    • E30SPDFRK
      • 5714
      You should only need a small roll. Its way easier and cheaper to do it as well.
      Byron
      Leichtbau
      • daniel
        • 6703
        roll them more. you have a good tire size and offset.
        http://instagram.com/dslovn.drives
        • evilnickwong
          • Aug 2007
          • 302
          Are you running very low suspension? I'm planning to use the same tire size on my 16x7.5 ET20 wheels.
          • Uber E30
            • 1409
            yeah im on 60/50's
            -Alex
            • e34john
              • Apr 2006
              • 3599
              Sounds like it might be rubbing on the inner fender not right on the edge so rolling it probably won't solve it. What suspension you running? It could be too soft.
              • Mystikal
                Wheel Fitment Expert
                • 9602
                That shouldn't rub, frankly. I'm wondering just how soft that setup is.
                • Uber E30
                  • 1409
                  Its lowtek 60/50's and lowtek shocks. All the bushings and other suspension bits are new.
                  Previous to this i was running 205/50/16 at et28 with no rubbing issues what so ever =[
                  -Alex
                  • bmws50b30
                    • Aug 2005
                    • 1151
                    can you tell where exactly the tires are rubbing? this will tell you a lot.
                    1991 330is
                    • Mystikal
                      • 9602
                      I ran that exact setup with GC coilovers at a fairly soft rate...never grazed even once, and that was with unrolled fenders! Is it rubbing on both sides?
                      • Uber E30
                        • 1409
                        Sounds like it
                        Not sure
                        -Alex
                        • Highway1
                          • Jan 2009
                          • 773
                          If they have rubbed there will be a mark. take your wheels of and poke you head in there and look all around with a flashlight. You will find a spot where the paint has been scuffed.
                          I just did this and found a spot at the top of the fender, past the lip, where my tires were rubbing.
                          • e34john
                            • Apr 2006
                            • 3599
                            If your car is too grimy and the tires don't show damage stick some masking tape inside the wheel wells and fender lips, go out and launce the car.
                            • sector6
                              • 909
                              Originally posted by e34john
                              If your car is too grimy and the tires don't show damage stick some masking tape inside the wheel wells and fender lips, go out and launch the car.
                              like this...
