shaving wheels
  • rede30
    • 4697
    shaving wheels
    to acheive a highter offset can i take my wheels to a machine shop and have them grind the center of my wheels from say a 18et to 20. or is that a hella lot of grinding or is that not even possible to grind. thanks
    Dustin
  • Jordan
    • 12916
    You can only remove a small amount of material. 2mm might be ok, or may push it.
    Most wheels have about 10mm of material between the lowest most lug seat, and the back face of the wheel.
    Remove what little material is there at your own risk.
    https://mtechniqueabs.com/
    • M3 Ryan
      Site Sponsor
      • 2298
      why not roll your fenders? I run an 18x8.5 et15 in the front of my car with a 225/40/18 tire and I am not hurting... of course I have about 2 inches more clearance than you would with a stock E30 fender 8)
      '88 M3.2 S54 Lachssilber/Black
      '07 335i Alpine/Black Sedan
      '12 X5 3.5i Alpine/Black
      iS Splitters For Sale, PM ME!
      • rede30
        • 4697
        Well i am going to roll my fenders but i am just wondering if a cupkit will work on my car with 17X7.5" 215 40's et18. i am not sure it will work out so just thinking of options. and yes you lucky basterd you do have a m3.:x
        Dustin
        • Jordan
          • 12916
          Helps if you mention what year your car is Dustin.
          • Mystikal
            Wheel Fitment Expert
            • 9602
            Those sound like LTW replicas. Am I right?
            Anyways, it'll be close, but you'll be fine with that setup. If anything, extremely minor rolling would do the trick. That setup is only 2mm further out than the common 225/Ronal combo, and those guys aren't rolling.
            • UNHCLL
              • 8790
              A Red E30.
              duh ;)
              early or late model ?
              Below the radar...
              • rede30
                • 4697
                its a 1989 and yes they are ltw
                • Jordan
                  • 12916
                  should fit with minimal or no rubbing.
                  rolling the fenders will fix any issues.
                  cupkit on later cars looks gay IMO. My car has the early higher arches, and I slightly tuck the tire on my 17's (215/40)
                  cupkit on a later car = tucking wheel in the back (with 17's)
                  Once you have 2-3 passengers in your car forgetaboutit. You will be tucking tire in front and wheel in back.
                  • Wes325
                    • 563
                    On my 325i I had LTW E36 M3 replicas on with 215yoko paradas and I was fine without hardly any rubbing issues at all, the front rubbed once and it was under hard driving.
                    - 318is 4 life
                    • Rob
                      • 8166
                      Machining wheels themselves sounds really really sketchy to me.
                      BEERTECH
