Can you guys runnin 16x9 rear rims let me know what final offset you have? I'm assuming ET12-15 would work....any help would be appreciated.
16x9 rim offset question?
Tags: None
With or without spacers? I would have thought 16x9 ET15 would come very close to the struts up front. My 16x7 ET28 wheels have about half an inch of clearance to the strut up front. 16x9 ET15 wheels would be half an inch further inboard by my calcs. So they'd be close :DOriginally posted by mikeedlermy azev 9x16 are ET15, fit fine
The thread is talking exclusively about the rear, 9" rims in the front need around 5-10mm more room.Originally posted by sovannWith or without spacers? I would have thought 16x9 ET15 would come very close to the struts up front. My 16x7 ET28 wheels have about half an inch of clearance to the strut up front. 16x9 ET15 wheels would be half an inch further inboard by my calcs. So they'd be close :DOriginally posted by mikeedlermy azev 9x16 are ET15, fit fineComment
Re: 16x9 rim offset question?
et5 front and et0 rear, I didn't have to run spacers out back with et15 but the fronts hit the strut housing.Originally posted by Chris E30 CabCan you guys runnin 16x9 rear rims let me know what final offset you have? I'm assuming ET12-15 would work....any help would be appreciated.
Thanks for the replies fellas........i'm ok in the front since they are only 16x8 ET20. The concern was the 16x9 ET20 rear....I suppose I'll go with a 5-7mm spacer then.
How bout rear tire size on that 16x9? Will 245's fit? Must be hard to find 245/16's? Obviously the fenders will be rolled and I'm trying to find some fibreglass or plastic flares......Zender use to sell them for the E30 but NLA......do you guys know of any others, besides BMPD & Ireland Eng?
haha, you'd be very surprised then to know that I have 3/4-1" clearance on the inside and 1/2" on the outside of my 17x8.5s, even with my (now gone) oversized 245/40/17 tires. I rolled the fenders just a little bit with a metal rod and eventually a ~5lb sledge
Dont run Spacers for the rear. It will fit just fine. There is plenty of room on the shock side for the rear, and your fenders will be better off.Originally posted by Chris E30 CabThanks for the replies fellas........i'm ok in the front since they are only 16x8 ET20. The concern was the 16x9 ET20 rear....I suppose I'll go with a 5-7mm spacer then.
Also, IE products are generally not made to "look nice" but to be functional. Keep that in mind if ordering fender flares. They don't come as a perfect fit either, you have to trim them to your liking.
332iS R.I.P.Comment
