Noob bbs rs question
  • daniel
    • 6703
    what the eff? i still don't understand wtf you are trying to ask.
    http://instagram.com/dslovn.drives
    • xwill112x
      • Jan 2009
      • 4236
      hes trying to put the outer "mesh" on the inside i think?
      • straight6pwr
        • Sep 2004
        • 3450
        is this what you mean?
        • daniel
          • 6703
          ah, so flip the wheel around and flip the face around so you can get a -250 offset, and a dish as large as the wheel is wide. makes perfect sense now.
          • chadthestampede
            • Jul 2008
            • 3601
            OP, don't listen to these people, they're just being dicks. I did that with my bbs, it works fine and looks even better. It works the best if you just cut the fender lip off all together, so you don't have rubbing issues. Tin snips work well for this step. Finally, take a hammer and round off the edges so you don't need to worry about sharp metal near your tires.
            Then cut about 3 coils off your stock springs and you should be good to go (if you want to run springs at all, I'm running custom made solid aluminum cylinders).
            Originally posted by LJ851
            Feedback
            • ono1
              • Nov 2009
              • 10
              Lol I knew what I was getting in to starting this thread :p
              • ThaiRacer
                • 799
                We should get a IP check to see who would created an account just to ask this and not look stupid on his real account.
                • Leaf
                  • Apr 2009
                  • 985
                  shut your face and get a lip
