Diamond Racing Wheels: Spacer and Lugs Question
  • GCARent
    • Nov 2009
    • 80
    #46
    Originally posted by S&E30
    Yes but I don't have rears yet cause I keep buying other things. Eventually I'll get some 15x10's for the rear. Right now im on Borbets.
    Nice photo! Crisspy... That looks really nice with that drop. Did you roll your fenders yourself?
    • S&E30
      • 83
      #47
      Yeah with a hammer, dolly, and heat gun in about 30 minutes. I would've preferred to have done it with a fender roller but I needed it done right away. I had to run a good deal of camber though.
      • 2002maniac
        • 4260
        #48
        say goodbye to your handling with 2" stagger
        • S&E30
          • 83
          #49
          Handling? HA! I run -3.6 deg of camber in the front and -4.3 in the rear with bad suspension geometry. I don't think I care about handling.
          • chad@velocitymotorcars
            • Dec 2009
            • 4
            #50
            Guy's not sure if you're still looking for spacers or not...but I can help you save a ton of money on 4/100 spacers for your car....but our 4 lug spacers have been reduced...on top of that we are offering another 10% off right now...so yes you can get a set of 4 - 10mm spacers for almost a $100... If you need bolts...these are extra..
              • Dec 2009
              • 4
              #51
              Originally posted by lifeiskaos
              I just tried adding 4 10mm spacers and my total was over $200...
              Well if your intent was to buy 4 SETS, which is 8 individual spacers...then yes the total would be around $200... But these are sold as a pair... So a QTY of 1 is a pair of spacers...
              • z50_Jumper
                • Apr 2007
                • 1520
                #52
                I love all the divingboard porn in this thread. I'm considering 16" diamond racing wheels. So in order to not have to grind anything, you could run spacers up front but then you would want more backspacking to bring the barrel of the wheel back in to make up for the spacer. This would = less dish but a better fit. So is it possible to run 6" backspacing for the rears with no issues?
                • S&E30
                  • 83
                  #53
                  The fronts need spacers so you could get 16x8 5.5" BS which would be about +12 and you could get 10mm spacers to make it +2. The rears don't need spacers because the mounting surface extends past the brake caliper, so you could still run a +0 offset in the rear on a 16x8.
                  • bataangpinoy
                    • Jul 2008
                    • 1636
                    #54
                    ^^. mhmm. im running the wheels the OP ordered, we traded for my euroweaves, then he sold his car :/
                    My feedback:
                    http://www.r3vlimited.com/board/showthread.php?t=186328
                    http://e30tech.com/forum/showthread.php?t=74911
                    Instagram:
                    @gears_n_glory
                    @functionmotorsports
                    • MSFIT
                      • 81
                      #55
                      I'm confused.
                      16x8 5.5" BS is 1.5" off center, 1.5" = 38.1mm how's that +12? Maybe I'm not sure how wheel offset's work.
                      I'm about to order some 16x8's and trying to make sure I'm doin this right.
                      Front: 16x8 4.5" BS w/ 10mm spacer
                      Rear: 16x8 4.0" BS no spacer ?
                      I'll be good with a 205/40 ya?
                      • Dj Buttchug
                        • Jun 2010
                        • 7648
                        #56
                        16x8 +0 will require a roll and slight pull to fit a 205 series tire
                        Turbo M42 Build Thread :Here
                        Ig:ryno_pzk
                        I like the tuna here.
                        Originally posted by lambo
                        • 1987_325is
                          • Jun 2010
                          • 106
                          #57
                          This shits hard to get straight without a pen and paper, if I were to run 15x8 wheels what BS would I need and what tire size would I need so that there was a ridiculous amount of stretch and I wouldn't have to roll/pull the fenders? I don't mind if I have to grind the caliper bracket, I've got the tools for it.
                          • Butler
                            • Nov 2009
                            • 1613
                            #58
                            bump because they are oddly attractive.
                            -Nick
                            Originally posted by 87e30
                            First of all: calm the fuck down; second of all; cool story bro.
                            • MaxBell
                              • 1391
                              #59
                              I'm about to put an order in, let me just run the numbers past you guys so I don't order anything retarded. I'm lowered a little on H&R Sports.
                              Fronts: 16x8 ET+12
                              Rears: 16x10 ET 0
                              What tires should I be running, maybe a 205/45 ish? I want a lil' stretch...
                              REMEMBER: Be safe and have fun is Rule Number 1.
                              The Epic Unbuild of Clint Eastwood
                              • Butler
                                • Nov 2009
                                • 1613
                                #60
                                ^^ Those seem like crazy offsets. I would think that they would be 16x8 ET0/16x10 ET12....
                                -Nick
